Multitimbral Analog?
intergalactic
Gear: Roland Alpha Juno 2
Yamaha Motif ES8
Yamaha PSR E-303 :)
MOTU 828 MKII
Mac Mini
Logic Express
Post by intergalactic » Sun Jan 18, 2009 3:56 pm
I am sure this has been addresses before but I couldn't find it in search. I was wondering if with a single multitimbral MIDI keyboard one could control two rack mount analog synths, on either side of the split? I suspect not or I would have seen a post about it. (Still learning about this MIDI stuff)
Thanks!
Re: Multitimbral Analog?
Post by meatballfulton » Sun Jan 18, 2009 4:04 pm
Yes, if the master keyboard supports transmitting on a different MIDI channel on each side of the split. Not all multitimbral synths do. As always, read the manual.
intergalactic
Yamaha Motif ES8
Yamaha PSR E-303 :)
MOTU 828 MKII
Mac Mini
Logic Express
Post by intergalactic » Sun Jan 18, 2009 5:17 pm
Cool, thanks! The question was as much for what buying strategy as anything. MKS-50s seem reasonable on eBay...
Mixolydian
Post by Mixolydian » Sun Jan 18, 2009 5:48 pm
The MKS-50 is a great place to start with analog. It's the most reliable and most plentiful of the MKS series. It can be set to any midi channel, and it's fairly easy to navigate the menus. Sysex is excellent. If you get one, don't worry about the PG-300 controller. The MKS-50 happens to be the only MKS that's controllable from a computer based editor. There's one called PG300EMU that works perfectly, and it's free.
BTW, I paid $150 for mine a few years ago. I think they still average $150 - $200.
modulator_esp
Real name: Jez
Gear: some synths, samplers, effects, sequencers and loopers :-)
Band: Modulator ESP
Post by modulator_esp » Sun Jan 18, 2009 6:02 pm
The Korg Wavestation can have up to 8 layered/split zones controlling external midi gear, with each zone having it's on midi channel
mostly enjoying adventures in sound :)
xpander
Post by xpander » Sun Jan 18, 2009 8:57 pm
.... or you can use max/msp to route your controller to whatever.
pflosi
Post by pflosi » Mon Jan 19, 2009 12:34 am
V-O-L-T-A
gs
Post by gs » Mon Jan 19, 2009 2:30 am
Mixolydian wrote:The MKS-50 happens to be the only MKS that's controllable from a computer based editor.
Pretty sure the MKS-70 can be controlled via MIDI/computer based editor as well. (But not its keyboard-based cousin, JX-10).
Mixolydian
Post by Mixolydian » Mon Jan 19, 2009 4:55 am
Oh how I wish that were true, but the MKS-70 has a 6 pin din socket for the controller. I can send sysex patch changes to mine, but they have to be in the cartridge format 1-50, not individual patches or parameters.
I did forget about the MKS-7, which can be edited by computer. It can also be connected to a Juno 106 and edited that way.
BTW, when I first read this question, I thought Intergalatic wanted to know if there were any multitimbral analog synths. The answer to that would be yes, at least three: Roland MKS-7, and the MKS-70 / JX-10 which can both be split into two separate synths with assignable midi channels.
Post by Stab Frenzy » Mon Jan 19, 2009 5:53 am
pflosi wrote:V-O-L-T-A
How would you use Volta to do what the OP is asking? Using for example a Kawai K5000W as the multitimbral midi keyboard and a DSI Prophet 08 rack as one of the analogue rack synths and an MKS-50 as the other?
Or have you just got a macro that's set up to type Volta into every thread without reading it?
pflosi
Post by pflosi » Mon Jan 19, 2009 10:56 am
it would work for anything that has several oscillator cv inputs.
OriginalJambo
Gear: Check my sig
Post by OriginalJambo » Mon Jan 19, 2009 7:31 pm
pflosi wrote:it would work for anything that has several oscillator cv inputs.
How many rack mount analogue synths do you know of that aren't MIDI capable?
HideawayStudio
Real name: Dan Wilson
Band: Shortwave
Post by HideawayStudio » Tue Jan 20, 2009 10:11 pm
Not sure if I'm misunderstanding your point but my JX-3P, JX-8P, MKS-50 and MKS-70 can all be programmed via midi - the sysex implementation on the JX series was superb. The Super JX is a tad broken but the MKS-70 is a little less and I believe a firmware update improves it.
AKAI did a 1U rack, ME25S "MIDI Note Separator" many years ago that allows to you to split the keyboard for exactly the purpose requested - some of these are still used on midi retrofitted analogs. You can transpose splits too.
steveman
Post by steveman » Tue Jan 20, 2009 10:54 pm
That'll be nothing apart from modulars then...
VOLTA looks great, but it's irrelevant to this thread.
