Post
by balma » Wed Sep 16, 2009 8:02 pm
As a sequencer, EMU command station can:
-Record, overdub edit, grid, etc, almost any edition function during the fly. You don't have to stop the sequencer in order to enter the edition screens of a lot of parameters. Can jump to almost everything while playing.
-sent a max of 30 tracks externally (using multitrack compressing A and B together functions) and play 14 local tracks, everything simultaneously. A total of 48 tracks per pattern.
-can transmit or play locally, 16 arpeggios at the same time.
-can change the pattern length while playing....(1 to 32 measures)
-can trasmit knob tweaks internally and externally at the same time. You can record on a single track, knob movements for 16 external tracks at the same time.
-you can compress the 16 tracks, into a single track, in order to release the other tracks for more recording.
-can record 300.000 notes.
-has 1024 positions for the patterns.
On song mode:
you can create a song chaining patterns. After that, you can record notes, knobs, WHATEVER, and layer it over the data stored on the patterns, without having to change the patterns. You can choose if the song will follow pattern events, or only song events, or both at the same time. Song will recall pattern's tweaks and song tweaks at the same time.
you can mix on the fly, the tracks of all the 1024 patterns into the current pattern playing. So if you are on pattern 20, you can bring any track from the pattern 21 into the current one, or can create from scratch a new pattern from other patterns' tracks, without stopping the sequencer.
It can control two midi devices at the same time.
the EMU's sequencer is really, really deep, intuitive and handy.
Well, I play live a lot, haven't found something similar on the market for hardware sequencer.
About the sound, both are romplers, but, command station's patches are more twekeable, and better for my taste.
I used the RM1X during certain time as my main sequencer.
The command station belongs to the Proteus family. There are around 30 different ROMS for it. Is totally customizable, thousands of sounds can be loaded into it. And the variety of waves available is simple astonishing.
You can layer 12 waves into a single patch using the Link mode. Can create your own tuning tables note by note, can create 100 user arppegios, with 4 roms, you can have access to around 1200 arps...
Can't even touch the EMU on that area. I noticed some cuts when changing patterns on the RMX1, the engine is a litte bit slow.... wow! forgot that. EMU saving functions, does not stop the sequencer, and you won't find any
"saving data, please wait"....
on the EMU. Everything is saved inmediatly.
Well. that was a good description, but there are even more features on it
