In the market for a drum pad controller
cornutt
Gear: 6th
Post by cornutt » Mon Nov 30, 2009 12:47 am
Well, after my last episode with Akai's bug-ridden firmware, I am about to go out in the driveway and smash my MPD24 with a sledgehammer, and I will never set finger to another Akai product again. So has anyone got any recommendations for a playable-with-the-fingers drum pad controller? Right now, the choices appear to be the Korg padControl, the Korg Nanopad, and the M-Audio Trigger Finger. I need at least 8-level velocity sense, and I absolutely must have the ability to change the MIDI note mapping. Everything else is negotiable.
th0mas
Band: GRAVITRONIC
Re: In the market for a drum pad controller
Post by th0mas » Tue Dec 01, 2009 6:14 pm
Don't get an m-audio axiom expecting velocity sensitive note triggering. From what I read in the manual (and experienced using it), while the drum pads are velocity sensitive, they can only sense velocity to send CC's based on pressure, and when sending notes the drum pads send a static velocity value that is preset in the patch.
Unless I'm missing something (which is possible, m-audio documentation is terrible)
steveman
Post by steveman » Tue Dec 01, 2009 10:21 pm
Happy with my PadKontrol - note mapping, velocity sensitive (pads feel fine, but I can't compare it to anything else) and a useful XY pad.
stikygum
Post by stikygum » Wed Dec 02, 2009 1:22 am
The PadKontrol is pretty easy to setup. I like it's pads also and enjoy the whole lighting experience you get while playing it.
Joey
Band: BLUSH_RESPONSE
Post by Joey » Wed Dec 02, 2009 8:10 am
I had the padkontrol once and it was great, and then I switched over to the nanopad and never looked back... either of the korg ones will do you good.
http://wearereplicants.com
Post by Stab Frenzy » Wed Dec 02, 2009 8:27 am
I checked out all the ones on the market a couple of years ago and I thought the MPD24 was the best built by a long shot. Never had any problems with bugs, maybe you just got a dud unit?
