What to I check before I buy Korg MS-10 (or any vintage)?
spybar
Post by spybar » Tue Feb 16, 2010 10:42 pm
Hello again dear friends,
So I'm thinking of getting Korg MS-10.
Since it's from 1978... and analog...
1) What should I check before I decide to get it?
2) Which parts?
3) Should I be prepared for any future problems?
4) What about tuning?
5) Mmm... I have read in Harmony Central User Reviews page that:
"The filter is a sealed component that are no longer in production and if this goes........bye bye MS10, as all audio has to pass through it!"
Should I be scared?
There aren't many places in my area that can fix such a synth...
Appreciate your views and inputs! I truly need them.
Thank you, :)
SpyBar
Hybrid88
Re: What to I check before I buy Korg MS-10 (or any vintage)?
Post by Hybrid88 » Wed Feb 17, 2010 3:36 am
I wouldn't worry too much about parts in a MS, just check that every function works, go throught every pot, key etc one by one and see if it's 100%, if it's not, suggest a more appropriate price to the seller, people will still try to rip you off with even a broken synth these days.
As far as the filter goes, I'm not sure what it's like with the MS-10 but with the MS-20, there were two revisions of the filter, and early version used the custom KORG35 chip that you mentioned, and the later chip uses a more easily replaceable design. Maybe the MS-10 only used the KORG35 version, I don't know. But any good tech should be able to reverse engineer the design should something go wrong with this version, also you can by replacements here -
http://www.synthrestore.co.uk/products.htm - Just scroll to the bottom of the page.
I think you should try not to pannick here, the MS range are quite possible to be fixed by practically any half-decent tech. Tuning is definately no reason to pass up a deal on a 10, all that means is that it needs a calibration as per the service manual, a fairly easy job and nothing to worry about.
Seriously though, just look at it this way, if something does go wrong, most likely it'll be an easy fix and not cost very much, until then, supposing everything works now, just enjoy it. Reliability issues go with the territory with vintage, if that's too much of an issue for you then get something new.
Cheers ;)
spybar
Post by spybar » Fri Feb 19, 2010 1:09 am
Dear Hybrid88,
Thank you. I appreciate your detailed inputs & view.
I will go to check... and mmm... maybe buy the MS-10 tomorrow!
I am thrilled... :D
More comments, inputs & views are welcome. :)
Cheers my friends.
SpyBar
Hybrid88
Post by Hybrid88 » Fri Feb 19, 2010 7:56 am
Cool, let us know how it goes ;)
