Strap on keyboards!
Strap on keyboards!
Hi everybody! I'm new here in the forum!
Could someone help me finding out some synths or midi controllers (if there is any) that can be strapped on but not so expensive as the new AX series from roland? I need it because I have to move on stage and I've thought that could exist some vintage model that I don't know and that could fit my needs.
Another question: is it possible to put two strap pins on a light midi controller without too much difficulties?
- Gear: Ensoniq SD1, Alesis Ion, iPad2 (running Animoog, Galileo Organ, iM1, iWavestation, Mellotronics M3000HD, & ThumbJam), Roland VR-09b.
- Band: The Journey Worship Band
Re: Strap on keyboards!
Yamaha DX100.
- Z
Casio CZ-1000
- Gear: sh-101, monomachine, nordmodular, esx1, nova, jx3p, jx8p, prophet vs, dx200
don't forget the sh101.
Not vintage bu the MicroKORG would be easy to strap on. Juust remove two of the screws holding the wooden side pieces and replace them with strap buttons.
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Casio AZ-1. Two MIDI channel-xmit, several control wheels, sliders... IIRC aftertouch. Make sure it works before buying... the custom MPU is made of solid unobtainium.
- Confucius
- Confucius
- cornutt
- Gear: 6th
OB-X.
- Automatic Gainsay
- Real name: Marc Doty
- Gear: Minimoog, 2600, CS-15, CS-50, MiniBrute, MicroBrute, S2, Korg MS-20 Mini, 3 Volcas, Pro 2, Leipzig, Pianet T, Wurli 7300, Wurli 145-A, ASR-10, e6400.
- Band: Godfrey's Cordial
What's he got, that I ain't got...cornutt wrote:OB-X.![]()
- organsymphony
- Real name: Sam
- Gear: an assortment of various friction idiophones
- Band: Parrot Fashion
i've had good success putting some strap buttons on an m-audio oxygen 8. i bought a rechargeable battery pack rather than using loads of AA batteries everytime. maybe look at the m-audio mid air as it has built in wireless midi rather than having to get a wireless midi unit or a really long cable. i just use a long cable into the midi in on my main controller.
i also put a little piece of 5mm aluminium behind the plastic and drilled through to just make the strap button more secure.
please whatever you do don't get a yamaha shs-10.
- Z
I just weighed my OB-Xa: 45 pounds. I'm sure the OB-X weighs that or more. That's a heavy keytar! I just weighed my KX5: only 7 pounds without 6 AA batteries.cornutt wrote:OB-X.![]()
- cornutt
- Gear: 6th
Wayne eventually had a tech take the guts out, put them in an offstage rack, and connect it to the shell via a long multi-conductor cable. I don't know how much weight it really saved. He has back problems now.Z wrote:I just weighed my OB-Xa: 45 pounds. I'm sure the OB-X weighs that or more. That's a heavy keytar! I just weighed my KX5: only 7 pounds without 6 AA batteries.cornutt wrote:OB-X.![]()
- Stab Frenzy
Yeah I've seen that done quite a few times, works well enough.Cumulus wrote:Not vintage bu the MicroKORG would be easy to strap on. Juust remove two of the screws holding the wooden side pieces and replace them with strap buttons.
