Analog Bass Synth - which one?
space6oy
Re: Analog Bass Synth - which one?
Post by space6oy » Thu Apr 29, 2010 9:40 pm
yeah, the dark energy is controllable via midi or usb. pretty awesome. that's just direct midi/usb translation of control voltage to the VCO and gate to the ADSR though, controlling its filter is different, that's arranged via signal path of other CV output, ie LFO. ableton won't exactly be able to change the filter's cutoff, for example.
f__p
Post by f__p » Thu Apr 29, 2010 11:16 pm
uhm.. Ithought you could assign the cutoff to the mod wheel and then control it from ableton (or any other daw)..
sqweebking
Gear: Roland, Moog, Yamaha, Korg, Novation, etc.
Band: sqweebking
Post by sqweebking » Thu Apr 29, 2010 11:36 pm
Studio Electronics SE-1 is nice, can get a SE-1x or do the resistor mod to the SE-1 if you need snappier envelopes. I really like mine, you want to talk about being able to rattle some walls, this thing goes super deep. I think it can be had for cheaper than an ATC too.
space6oy
Post by space6oy » Fri Apr 30, 2010 12:19 am
f__p wrote:uhm.. Ithought you could assign the cutoff to the mod wheel and then control it from ableton (or any other daw)..
to what mod wheel? it'd have to be one that output a control voltage, and even then for ableton to control that there would have to be a midi-cv converter.
monolith
Post by monolith » Fri Apr 30, 2010 12:49 am
space6oy wrote:ableton won't exactly be able to change the filter's cutoff, for example.
Unableton? :D :drums: :facepalm:
Post by Stab Frenzy » Fri Apr 30, 2010 3:07 am
The Dark Energy's CV convertor has an output for mod wheel CV.
space6oy
Post by space6oy » Fri Apr 30, 2010 5:16 am
but what has to be used for that? doepfer keyboard?
Post by Stab Frenzy » Fri Apr 30, 2010 8:47 am
Anything that sends midi mod wheel info. You can plug in any midi keyboard or you could even just draw the mod wheel automation in Live. :thumbleft:
JJQ
Post by JJQ » Fri Apr 30, 2010 9:56 am
Since nobody voted for the ATC-1, Ill give it my support.
It sounds good.
I dont remeber it the SH-2 has VCF CV in, if it has thats a very good one.
Gear: Minimoog, Mother-32, Roland MC-202, TB-303, (Boss) DR-110, TR-505, TR-808, Alpha Juno 2, Jupiter-8, Oberheim SEM, .com/oakley/moon/mos-lab/STG/Sputnik/MegaOhm-modular & Microbrute
CS_TBL
Gear: All "In-The-Box"
Mainly FM8
Post by CS_TBL » Fri Apr 30, 2010 10:35 am
How about 'any decent synth'?
Is there any reason why common 'full range' synths couldn't be used for basses?
FM8 vids
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Fri Apr 30, 2010 10:43 am
Some analogs that used early digital envelopes, the envelopes aren't quite as snappy as one usually wants for a bass.
space6oy
Post by space6oy » Fri Apr 30, 2010 6:30 pm
Stab Frenzy wrote:Anything that sends midi mod wheel info. You can plug in any midi keyboard or you could even just draw the mod wheel automation in Live. :thumbleft:
that's awesome, but i don't get it - is there a cv out jack on the dark energy specifically for the mod wheel message it receives via midi from the controller?
aeon
Post by aeon » Fri Apr 30, 2010 7:07 pm
Roland SH-2/09 is great for this. I love the envelope response on these VCO bass machines.
cheers,
Ian
Post by Stab Frenzy » Sat May 01, 2010 1:40 am
Yes. And velocity, pitch wheel, note and gate. It's the same as the A-190-2 module.
space6oy
Post by space6oy » Sat May 01, 2010 1:57 am
huh, cool! didn't know that. just controlling my modular via mobius.
