USB synths?
USB synths?
Hi everybody!
I'm interested in finding a usb synth (i think), and I'm hoping you might have some suggestions. I used to make quite a bit of music; hip hop, techno, industrial even.
Do you have any ideas? I haven't really seen much with usb other than the new Roland boards and Novation. I can budget under $500.
- Stab Frenzy
Re: USB synths?
What do you want the USB port to do? Midi? Audio? Data backup?
- Real name: Jonathan
- Gear: Yamaha DX11
Casio HT-3000
Apple iPod Touch
Korg MINI-KP
Several guitars
Re: USB synths?
May be wrong, but does the Microkorg XL have USB? If so, I think that might be a decent synth for you.
I'm a synth newborn, a stillborn if not.
...ew.
...ew.
Re: USB synths?
I would like the usb port for midi, audio and backup. Also like the idea of avoiding midi and audio cables. I already have a lot of cables in my work area, and want to keep it clean. I know it sounds dumb.
I just looked it up, and the XL does have usb. Does it output audio? I have heard the software editor is great.
- Real name: Unpronounceable
Re: USB synths?
No. Very few send audio over USB... the current Novations, and the Virus Ti line. I can't think of any others...ems wrote:I would like the usb port for midi, audio and backup. Also like the idea of avoiding midi and audio cables. I already have a lot of cables in my work area, and want to keep it clean. I know it sounds dumb.
- ninja6485
- Gear: Virus Ti, Jx-8p, Juno 60, Radias, Maschine, 101,303,606,707,727,808,909, odyssey, mirage, akai s5K/s2K/s1k, drumtraks, E6400ult, M1R, rx5, fizmo,d50
- Band: Subliminal Sea
Re: USB synths?
check out the virus ti snow: looks beautiful
- Stab Frenzy
Re: USB synths?
Audio over USB and <$500, this is your option:
Novation Xiosynth
If you include second-hand as well you get:
Novation X-Station
Roland SH-201
So not many options, should be pretty easy to choose.
Novation Xiosynth
Novation X-Station
Roland SH-201
Re: USB synths?
I wish.. the virus snow is such a beautiful synth. It's price is a bit too high.
When I get off work tomorrow I'll try to check out the 201. I didn't like it the first time I played, but this time I'll be more open minded. I think I was put off by the build quality.
I never even considered the microkorg xl until now, but I'll check it out too.
- meatballfulton
- Gear: Logic Pro X
Re: USB synths?
Yep, audio is always the kicker...backup and MIDI are well implemented on most machines these days. Why other mfrs have kept out of this space amazes me.
The Virus TI is the best implemented but because they use USB 1.1 rather than 2.0 there's only 3 stereo channels available...2 in and 1 out. I owned a Snow for a while and it worked 100% as advertised. Though out of your $500 range, you can find used ones for $800 (I did) maybe less if you're real patient.
Novation's big plus is USB will power the synth which is very handy for laptop applications, esp. gigging. One less wall wart and one less opportunity for ground loops.
- Stab Frenzy
Re: USB synths?
I think it's down to the fact that you need to write drivers, then keep them updated, and then deal with people being unhappy if they don't work 100% of the time. Novation have their interface division so they can share code with them, same with Roland and Edirol, but for a smaller team like Waldorf or one without experience doing that already like Korg they'd need a big investment in it to get off the ground. I guess it's where things seem to be going at this stage, but some companies have bigger R&D budgets than others.meatballfulton wrote:Why other mfrs have kept out of this space amazes me.
Microkorg XL doesn't do audio over USB.
- th0mas
- Expert Member
- Band: GRAVITRONIC
Re: USB synths?
It's probably 100x harder to have audio over USB than it is to have MIDI over usb. One is using very little capacity and the other is pushing the entire USB system to it's limits and you will often run into weird bugs in either host or slave's endpoint chipsets, drivers, or some combination thereof.
(I am a firmware engineer who has dealt with USB 2.0 communications issues. not fun)
- krzeppa
- Real name: Kevin J
- Band: Where the Embers Fall
Re: USB synths?
+1 on the Xio....Pretty good synth at a really cheap price....build quality isn't all that great, but for the price I thinked they packed as much as they could into it.Stab Frenzy wrote:Audio over USB and <$500, this is your option:
Novation Xiosynth
Novation X-Station
Roland SH-201
Also, not really sure when the Novation Ultranova will come out, but that has USB as well. I think the price on that is going to around 700 bucks though.
- Roby31
- Real name: Roberto
- Gear: Waldorf Micro Q (Yellow)
Access Virus TI 2 Desktop
Casio VL-1 - Location: Biella, Italy
Re: USB synths?
Stab Frenzy wrote:I think it's down to the fact that you need to write drivers, then keep them updated, and then deal with people being unhappy if they don't work 100% of the time. Novation have their interface division so they can share code with them, same with Roland and Edirol, but for a smaller team like Waldorf or one without experience doing that already like Korg they'd need a big investment in it to get off the ground. I guess it's where things seem to be going at this stage, but some companies have bigger R&D budgets than others.meatballfulton wrote:Why other mfrs have kept out of this space amazes me.
Again I have to agree with Stab. The amount of users who don't understand this in the case of the Virus TI is ridiculous.
A little correction for an earlier post: the TI line has three stereo outputs over usb, not two. 3 outs + 1 input. They become 3+0 or 2+1 only when you use it as a sound card.
Re: USB synths?
I'd suggest Novation X-Station or XioSynth as well.
I have Novation X-Station 49 and it's like having something like FastTrack Pro built into your synth.
For a newb like myself with a small budget, X-Station has become the central part of my set up.
It does all the things hardware VA synth should do and also has audio-usb interface that connects up my guitar and mic simultaneously.
