Theoretic "huge" modular
Re: Theoretic "huge" modular
If you we're to patch all that up, you might find it sounds quite a bit like an analog polysynth you already own.
- Real name: Douglas
- Gear: tech nine, bag of coke, an erection and a hostage
pflosi's advice to buy just enough to make simple patches is best i think. Build on it slowly over time.
I cheated and just got the nord modular. Cheaper, and there is this lovely resource too which is using a nord for patch examples.
http://www.cim.mcgill.ca/~clark/nordmod ... k_toc.html
I might not have the modular bug quite yet though. I seem to make the most boring a*s patches on it. Like generic LFO>Cutt off Freq type stuff. Totally freaking boring, but there is a patch there that helps circumvent that "digital sound" which is kind of cool.
- sequentialsoftshock
- Real name: Zayne
- Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
I wish I could simply detune each individual oscillator on the BitOne or Prophet Five.
Cant you use auto tune on the p5 to detune the oscillators?
- Automatic Gainsay
- Real name: Marc Doty
- Gear: Minimoog, 2600, CS-15, CS-50, MiniBrute, MicroBrute, S2, Korg MS-20 Mini, 3 Volcas, Pro 2, Leipzig, Pianet T, Wurli 7300, Wurli 145-A, ASR-10, e6400.
- Band: Godfrey's Cordial
15 sine oscillators.
15 envelopes (for amps).
15 envelopes (for LFOs).
15 amps.
15 LFOs.
15 channels of mixer.
You're set.
15 amps.
15 LFOs.
You're set.
- Real name: Zayne
Automatic Gainsay wrote:15 sine oscillators.
15 amps.
15 LFOs.
You're set.
Why ? I can't tell if you're being facetious / trying to make an a*s of me..?
- bouzoukijoe1
+1 pflosi. start slow. you're going to need more than just VCOs. slowly add individual modules as you progress, and start with a balanced basic voice first. you will soon find out that for every VCO, you need various support modules.
a balanced starter system would be something like:
and don't forget: waveshapers and wavefolders which are becoming more and more common in many systems. warning: there is a vast world to explore beyond multiple VCO patches.
out of my 60+ modules, I only have 6 "proper" VCOs. the rest are various other types (some of which can be oscillators too, like Maths, Dr Octature).
good luck!
- min. 2-3 VCOs (consider dual-duty VCO/LFO modules -- more bang for your buck)
- min. 2 VCA channels (one for audio control, one for cv modulation when needed)
- min. 2 ADSRs (or a more flexible function generator like Maths/Quadra with EOA, EOC, voltage control of stages, linear/expo variable curve, etc.)
- min. 1 multimode filter or combination of two (HP+LP)
- min. 1 mixer (for audio and/or cv mixing, Xmix is a great example because it's multi-functional -- also a balanced modulator, xfade, etc.)
- cv tool/utilities for attenuation, offset, etc. (like CV Tools, A-183-2, Maths, TriAtt, etc.)
good luck!
- Automatic Gainsay
I don't want to make an a*s of you!sequentialsoftshock wrote:Automatic Gainsay wrote:15 sine oscillators.
15 amps.
15 LFOs.
You're set.
I'm actually not being facetious… but I suspected that people would think I was.
What I'm advocating is an additive arrangement as opposed to a subtractive arrangement. In this arrangement, you'd have a fundamental and 14 harmonics to work with… which would allow you to make a broad diversity of timbre. The amps/envelopes would control the amplitude of the harmonics over time. The LFOs/envelopes would control frequency variations of those harmonics over time.
As filters engage in wholesale removal of harmonics, with an additive arrangement you have a far greater control over harmonic content, and you don't need any filters. With an arrangement like this, you might also be able to roughly duplicate acoustic sounds.
- Real name: Zayne
That was my alternate thought. Additive synthesis. How many people do additive with their modulars ?
- Real name: Zayne
Could one of the mods move this to Buyers Guide ? That's probably where I should have actually put this thread.
- RetroSynthAds
I'm embarrassed to admit that I cheated a little when I first starting putting my eurorack together by including a Doepfer A-111-5 Mini Synth Voice module as part of phase 1. This way I knew I had at least one VCO, VCF, VCA, ADSR, and two LFOs, along with a variety of inputs and a few outputs.
I also figured that if I later thought I made the wrong decision to not put that money towards expanding my old Moog Modular, at least I had one whole synth voice to integrate into my studio.
I ended up buying a second one when I heard they were discontinuing the original version.
Buying five of them may be overkill though. And you may have to re-classify your system a "semi-modular".
d**k Martini
If you are bored... check out my blog: http://retrosynthads.blogspot.com
- Stab Frenzy
I started with a Z3000, Z2040, Envelator and A190-2. That gave me an oscillator, filter with VCA, Envelope (Only AD or AR, but that works for what I wanted to do) and a Midi/CV interface. Within a few weeks I'd added an e350, A132-3, A138-m, Vulcan Modulator, SEM-20 and a bunch of other stuff.sequentialsoftshock wrote:What did most of you start with ?
Whenever anyone starts thinking about a modular they always forget to add enough mixers, VCAs, attenuators, mults etc which actually allow you to do the modular part of using a modular. If you just buy a few oscs, a filter, an envelope and a VCA then you have a system that's pretty much a really limited monosynth. The power of a modular is in the ways things can be interconnected, as the number of modules increases the functionality increases exponentially.
- tekkentool
- Real name: Steve
- Band: none currently
Sounds prohibitively expensive.sequentialsoftshock wrote:That was my alternate thought. Additive synthesis. How many people do additive with their modulars ?
- bouzoukijoe1
probably rare. it's too expensive and also probably a pain in the a*s to get all the VCOs to track consistently with each other. maintaining the harmonic structures sounds like it would be a hassle. anyway you could probably do a basic one, but I can't imagine it being any "fun". there's are many other fun things to do on a modular, especially when you start approaching the atonal music world (just generally stuff that is not so harmony-based).sequentialsoftshock wrote:That was my alternate thought. Additive synthesis. How many people do additive with their modulars ?
for a brief time I was obsessed with FM synthesis and frequency ratios on modular but then it became completely *not fun*, real fast. imo there's just some things that are more pleasurable to do on a modular than others. well, right now at least, until someone designs a new module that pushes the boundaries.
- pflosi
My modular is for processing mainly so far... A proper "synth" and complementing sequencing will follow soonsequentialsoftshock wrote:What did most of you start with ?
I started with Intellijel Audio Interface, MMF1, A124, A199, A-142-4, PEG, SCM, 4ms VCA Matrix and some mixers and mults. In the meantime, it's grown to this:
Still awaiting Res4 and Pamela which hopefully should ship in the next weeks...
