Page 2 of 5
Re: Waldorf Blofeld
Posted: Wed Apr 03, 2013 3:44 pm
by zoomtheline
Get one. I have two and love them even despite the freezes and glitches. The sound and flexibility outweight the issues. As Colorform said above... The display is really intuitive and helps you grasp synthesis quite easily. It taught me better routes to go about my waldorf Pulse which I have used for years before getting a Blofeld.
It's cheap, easy to use and very deep if need be. Try it, I can't recommend any other synth for ease of use over this without going simple vintage mono or a Juno maybe. No other VA will walk you through synthesis like the Blofeld.
Re: Waldorf Blofeld
Posted: Wed Apr 03, 2013 8:07 pm
by Plumpudding
The Blofeld rocks. You can get anything from pure beauty to utter madness out of it, with a little dedication. I find the interface very well laid-out and easy to grasp. I haven't had a lot of glitches with the latest os. Just be aware of the encoder-related problems. My main is glitchy, and it's a pain.
Re: Waldorf Blofeld
Posted: Wed Apr 03, 2013 10:11 pm
by zoomtheline
There is a fix and it works pretty well if you don't mind a bit of soldering.
http://m.youtube.com/#/watch?v=HgECBaVp ... gECBaVp-wc
I think this vid shows the fix.
Re: Waldorf Blofeld
Posted: Wed Apr 03, 2013 10:54 pm
by meatballfulton
That fixes the encoders (they should do it when they build them) but is no help with the OS bugs related to clock synching.
Not to scare him away, but I think a newbie should at least understand the Blofeld OS isn't as bulletproof as typical Korg, Roland, Yamaha, etc.
Re: Waldorf Blofeld
Posted: Thu Apr 04, 2013 7:13 am
by zoomtheline
True but I don't think the dude is going to be running into those issues yet. I know I don't have those issues and I use the desktop for live use too.
Re: Waldorf Blofeld
Posted: Thu Apr 04, 2013 10:04 am
by Plumpudding
meatballfulton wrote:Not to scare him away, but I think a newbie should at least understand the Blofeld OS isn't as bulletproof as typical Korg, Roland, Yamaha, etc.
Ofc. That said, I've only had the OS glitch out on me a couple of times in the time I've had mine, and only once live, when it suddenly stopped receiving midi and sending audio. That was quite a scary moment, looking from the audience to my collaborator, tearing my whole setup apart to try and fix it, hah. I haven't had any problems after I installed the latest OS, though.
I tried the fix linked earlier in this thread, but my main encoder is still glitchy. It worked on all the others though. I just dial slowly with the main, one click at the time... works well enough. Patience is still a virtue I guess.
Re: Waldorf Blofeld
Posted: Mon Jul 15, 2013 10:48 pm
by Jabberwalky
Might as well post the question here. This seems like a cheap digital, crunchy, wavey sort of synth. I have the Sq80 covering a good amount of ground there, but this also looks really interesting and unique. I'm torn between this or the Evolver. Would anyone that's owned both like to give their opinion? Has the new OS on the Blofeld fixed the problems?
Re: Waldorf Blofeld
Posted: Mon Jul 15, 2013 11:53 pm
by cgren72
Jabberwalky wrote:Has the new OS on the Blofeld fixed the problems?
I've not had any problems with the new OS.
Re: Waldorf Blofeld
Posted: Tue Jul 16, 2013 12:40 am
by Hugo76
There is an iPad editor for the Blofeld just released:
http://www.idesignsound.com/blindcontrol-ipad/
Re: Waldorf Blofeld
Posted: Tue Jul 16, 2013 3:06 pm
by Rick N Boogie
I'm likely to trim down to only 2 synths, my Blofeld and Evolver keyboards. I couldn't pick one of the two, as they are so completely different. Monosynth with 16x4 step sequencer vs. a fully polyphonic digital- you'd have to make some choices.
Re: Waldorf Blofeld
Posted: Tue Jul 16, 2013 3:53 pm
by Infinity Curve
meatballfulton wrote: the OS bugs related to clock synching.
This was my main beef with it, it was a b***h to get it to sync. All those awesome arps/clock sync'd modulations, but it really didn't like to stay in sync with external clocks, and would drift noticeably pretty quickly. It was quite frustrating when you are trying to record parts, and they keep drifting off time. It did sound awesome though!
Fairly certain I was on the latest OS, unless they released another one in the last year.
Still might pick one up again since they come up used and super cheap quite regularly around here. Maybe go for the keyboard version.
Re: Waldorf Blofeld
Posted: Tue Jul 16, 2013 4:43 pm
by Jabberwalky
I'm thinking keyboard as well. The added sample memory seems worth it. Any comments on the build quality in regards to keys and knobs on the keyboard version??
Re: Waldorf Blofeld
Posted: Tue Jul 16, 2013 4:59 pm
by Ashe37
Jabberwalky wrote:I'm thinking keyboard as well. The added sample memory seems worth it. Any comments on the build quality in regards to keys and knobs on the keyboard version??
You know the sample memory is available for the regular Blofeld as a software upgrade, right?
the know quality on the KB is basically the same...
Re: Waldorf Blofeld
Posted: Tue Jul 16, 2013 5:27 pm
by Jabberwalky
I did see that on the page. After listening to a jexus demo I'm impressed by its depth.
Re: Waldorf Blofeld
Posted: Tue Jul 16, 2013 5:40 pm
by tallowwaters
Jabberwalky wrote:Might as well post the question here. This seems like a cheap digital, crunchy, wavey sort of synth. I have the Sq80 covering a good amount of ground there, but this also looks really interesting and unique. I'm torn between this or the Evolver. Would anyone that's owned both like to give their opinion? Has the new OS on the Blofeld fixed the problems?
I've had both, and they are quite complementary of one another.
My experience was that the Evolver put Evolver all over my tracks, while the Blofeld was easier to push into the foreground or background. This is likely due to the way I used them, but the Blofeld seemed a little more versatile, at least with the polyphony, if nothing else. While the Blofeld can certainly get crunchy, it has a sort of glassy, digital gloss to most all of its sounds. The Evo is going to have the most overlap with SQ80 in regards to general character.
Personally, I think owning the desktop version of both would be a good idea, but that's not very helpful is it?
