CV Gate converters??
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Fri Mar 08, 2013 11:58 pm
okay, I tried searching this on several sites as well as google.
Essentially I am trying to get a Roland SH09 to play nice with my other gear. Which includes a lot of Moog stuff and a couple Doepfer Dark Energy boxes.
Unfortunately the Roland wants 7.5v for it's gate, while everything else I got tops out at 5v.
I tried doing crazy stuff liek running the gate through a clean boost pedal. But apparently those specifically do not pass DC, which a gate signal pretty much is.
It works fine in the other direction of course, the roland gate will trigger most of my other stuff just fine, being that it's going "downhill". I do worry a wee bit that the extra 2.5 volts may be a bit much for my delicate noise boxes.
Is there some well known workaround for going "uphill"?
Or is there a box I gotta buy?
Please tell me I m just using daft search terms and such a box does exist.
I can live with Roland/Korg sync issues, it just makes my X0X play twice as fast.
But the no trigger stuff is kind of a bummer. I can imagine all kinds of fun stuff I could do with the gate, CV, filter and the LFO/Envelope switch. If only I could kick over that gate!
Re: CV Gate converters??
Post by meatballfulton » Sat Mar 09, 2013 12:44 am
I have seen modules that can multiply CV/gate signals (I had a dotcom unit that could do 0-200%).
I have not seen a standalone box that can do this.
Try asking over at Muff Wigglers.
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Sat Mar 09, 2013 12:52 am
I am sure there is a solution in eurorack land. I am actually trying to avoid going modular right now.
First it is kind of a weird trendy thing right now which I don't understand.
second I am a total gear w***e with no self restraint,so as soon as I get a modular case I will spend all my disposable income on filling it up.
I am a completely untalented electronics hack. But I think I may just have to dig through the Library's collection of Traister and Mims books to find a schematic that does this. Then just build a box myself.
But then I am 3 deep on soldering projects at the moment.
synthroom
Real name: Kirk
Post by synthroom » Sat Mar 09, 2013 6:57 pm
What about this:
http://www.synhouse.com/originalmidijack.html
Claims to work with the SH-09 and directly gives you midi in as well.
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Sat Mar 09, 2013 7:21 pm
I'm not interested in midi.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Sat Mar 09, 2013 10:27 pm
Try putting a 1.5 volt drycell in series with the trigger.
- Confucius
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Mon Mar 11, 2013 12:39 am
rhino wrote:Try putting a 1.5 volt drycell in series with the trigger.
that would get me to 6.5 volts, not 7.5. It would also offset the 0 to 1.5V+ as well right?
bouzoukijoe1
Post by bouzoukijoe1 » Mon Mar 11, 2013 7:16 am
this is very true about eurorack. it's the trendiest thing going on right now. but it took me all of 10 seconds to offset and attenuate a 10V pp AC pulse into a perfect 7.5V DC gate using an A-183-2. can't get any easier than that for clueless noobs like me. s**t is instant. not the cheapest solution, but definitely easy. if you already have DE's, you might as well get a small euro case for auxilliary modules. lots of fun to be had.
A-183-2 - $65
uZeus + power - $105 (build your own enclosure)
or A-100 minicase - $120
I cheated with a Jones scope though so I could hit the nail on the head at 7.5V.
calaverasgrande
Band: N.S.V.
Post by calaverasgrande » Mon Mar 11, 2013 7:27 am
bouzoukijoe1 wrote:this is very true about eurorack. it's the trendiest thing going on right now. but it took me all of 10 seconds to offset and attenuate a 10V pp AC pulse into a perfect 7.5V DC gate using an A-183-2. can't get any easier than that for clueless noobs like me. s**t is instant. not the cheapest solution, but definitely easy. if you already have DE's, you might as well get a small euro case for auxilliary modules. lots of fun to be had.
A-183-2 - $65
goddamn it there is a eurorack oscope?
You bastard, that is nerd kryptonite. Now I have to get a eurorack set up just for that.
You are so going to h**l.
You bastard. </peter griffin voice>
bouzoukijoe1
Post by bouzoukijoe1 » Mon Mar 11, 2013 8:45 am
lol yes and you have more options than one, thanks to Dave Jones. :)
if your flavor is Moog Units, I believe SSL is coming out with one too (coming soon). http://steamsynth.com/ModulesMU.aspx
Altitude
Post by Altitude » Mon Mar 11, 2013 8:08 pm
Just build a level shifter on protoboard. You would need only a few parts: CD4069 Hex inverter, 7.5V (or ajustable) Vreg, a load resistor, some caps
bouzoukijoe1
Post by bouzoukijoe1 » Tue Mar 12, 2013 3:53 am
CSQ-100!
Altitude
Post by Altitude » Tue Mar 12, 2013 2:23 pm
or $3 in parts
Post by meatballfulton » Tue Mar 12, 2013 8:11 pm
OK, so use two ;)
The 0V is not that important, as long as the voltage drops significantly below 7.5 it should work.
synthroom
Real name: Kirk
Post by synthroom » Wed Mar 13, 2013 2:43 am
bouzoukijoe1 wrote:CSQ-100!
I've got a CSQ-100. It's a lot of fun!
