Cheap old sampler
Cheap old sampler
Hello all! I'm looking for a sampler similar to a akai s950 or s900. But I'm wondering if there are cheaper options . My requirements are to be able to transpose a sample across a keyboard, pitch shift and time stretch. Iv seen other akai s models for cheaper than the s950 but I can't confirm if they have pitch shift and time stretch. Also would be nice to have a adsr or Lfo. Also must be in a rack configuration as I'm low on space.
Plan to use it for ala skinny puppy/ministry type sample work. And want to thru some digital wave forms from a esq1/prophet vs for light synth work. Also doesn't have to be low bit sampler if there is a cheaper unpopular model like a 16 bit, would be fine.
Thanks for any info.
Also previous vse user here, been about 6 years. Great job to the web masters and contributors for keeping this site updated and looking good.
- Jay200MPH
- Junior Member
- Gear: Currently active:
x0xb0x, MC-202, Microkorg, PSR-36, mini-KP, SA-5, JV-1010, S-760, CMU-800.
Sequenced in Impulse Tracker on a P233 w/AWE64+GUS. - Location: Auckland
Re: Cheap old sampler
Roland S7xx can do all that & has great filters too. They seem to go pretty cheap in the States.
I just picked one up but haven't had time to really explore it yet. Very cool piece of gear though. The full-screen video out feature is awesome!
- Z
I don't think there are any 12 bit samplers that do time stretch. I don't remember time stretch coming along until the mid/late 90s and by then all samplers were at least 16 bit.
Before that, we'd take our 12 bit loops and run them through pitch shifters like Korg DVP-1 and Yamaha SPX90.
S950 can timestretch. I think TX16W can with Typhoon OS, but I'm not sure.
If you don't care that much about "lofi," try to find like an s2800 or something. I once got one for $20 when I was buying a case off a guy. S3000 series Akai are really cool. Definitely cool with the extra filter card, but still pretty cool without it. I think they can timestretch. I don't think E-mus had timestretching until e4s.
- mpa1104
- Gear: Finally, enough gear that exceeds the 150 character allowance. WooHoo - I qualify as an obsessed gear-head!
Ensoniq ASR 10 will do time expansion and compression. You can also downsample to lower bit rates for lo-fi stuff. There was a rack version, but haven't seen one around for a while.
- madtheory
- Real name: Tomas Mulcahy
Yup, it can timestretch. With Typhoon it's a much nicer box to use than an S950. Brighter, slightly harder sound.plus321 wrote:I think TX16W can with Typhoon OS, but I'm not sure.
But you can do all of that stuff and more with Kontakt. The SP1200 emulation sounds a lot like low sample rate on an S950 or TX16W.
Thanks for all the advice! I looked into recomendations and a Roland s330 can be had for dirt cheap. Is it "usable" without having add on controllers and moniters? or is it worth paying a little xtra for an akai s series ?
I guess it comes down to ease of use as a stand alone unit, out of what was recommended.
- madtheory
Purely for ease of use, the TX16W with Typhoon beats most hardware samplers.
- Jay200MPH
- Junior Member
I'm not 100% sure but I don't think the S330/S550 can do time stretch. They are a generation older than the S7xx but still very interesting instruments in their own right. (This video of an S330 was what got me looking into them in the first place - pretty cool stuff!)Bloodonmyface wrote:Thanks for all the advice! I looked into recomendations and a Roland s330 can be had for dirt cheap. Is it "usable" without having add on controllers and moniters? or is it worth paying a little xtra for an akai s series ?
The S330 won't have much RAM unless it's been upgraded. I imagine using one without a mouse & display would be a pain. You can plug in any old TV to its composite display port or an Amiga/etc. RGB monitor if you feel like building a simple cable. There are plans for a cheap PS/2 mouse adapter but it's a little more involved (including programming an EEPROM.)
It will load its OS off a floppy so make sure you either get one with it or have a computer with a floppy drive so you can write one (the OS image is kicking around, e.g. here - great site BTW!) The 330 and 550 can also run the Director-S sequencer which the later 700s can't.
All that said, if it's cheap enough just go for it! You can always use it as-is for the time being and get the rest of the add ons later, remember these were very high-end instruments when new.
Edit: here's a blog post with a 'review' and some great info on the S330. Read down into the comments too as he solves some of the issues he mentions and follows up.
Cool thanks for the info guys n gals. I'll keep my eyes peeled for your recomendations. Im hoping to score one 75 bucks or under including shipping. It seems like a great time to buy a hardware sampler, prices for even an akai s6000 are like 300 bucks.
- Junior Member
- Gear: MPC60
Cheaper option is the EPS 16+ rack, which can downsample to much lower bitrates then the ASR10. I see them going for super cheap too, like $150 range. Its my favorite sampler by far.mpa1104 wrote:Ensoniq ASR 10 will do time expansion and compression. You can also downsample to lower bit rates for lo-fi stuff. There was a rack version, but haven't seen one around for a while.
Ok kept an open mind and searched alot for a steal. It's not the Cheapest sampler but I got my money's worth.
Akai s5000 with expanded ram off local criagslist for 150 bucks. I am a happy camper
I just started rebuilding a small setup so I actually don't have anything with midi to control the akai s5000 yet. Been eyeballing some prices and looks like the cheapest smaller sized keyboard with midi is novation x-station, microkorg and Alesis micron. I would love something like a Yamaha sy22 but I just don't have the space.
Any advice on a smaller keyboard with midi thats usually found cheap please give me your thoughts and recomendations.
alesis q49
- Jay200MPH
- Junior Member
That sounds like a pretty good deal. Had a look at the S5000 on the VSE main site; I didn't realize those were so powerful! I like the DOS disks and WAV sampling. The removable keypad/screen is cool too (I have a primitive version of that for my Roland.) Nice score, you'll have fun with it!Bloodonmyface wrote:Ok kept an open mind and searched alot for a steal. It's not the Cheapest sampler but I got my money's worth.
Akai s5000 with expanded ram off local criagslist for 150 bucks. I am a happy camper![]()
- Gear: Nord G2 Engine, Roland VariOS, custom Akai MPC2000XL, Akai S612, Korg TR-Rack, Korg Prophecy, Oakley Filtrex 2
^^^ I would have suggested an S5000, people are/were flogging them off v.cheap. I bought two the other month.
