Korg Poly 61 for $300 too much?
Re: Korg Poly 61 for $300 too much?
Postby sam » Fri Mar 07, 2014 9:39 pm
I have fixed a few of these....The battery needs urgent replacement and those switches are hard to fix plus many other connectors go bad inside....Sounds ok but the lack of parameter control is a killer.
Don't pay that much..
Lam memorymoog.Sonic six.Vp330 mk1.SH101.OSCar.ARP odyssey..multivox mx3000.Solina stringsynth.polivox
ms20/50.Andromeda. OBX.
Prophet 5 Pro-one. Wasp.EMS AKS.
sam
Postby synthmaniak » Fri Mar 07, 2014 9:44 pm
ryryoftokyo wrote:Way too much. $125 or no deal.
yea right?. Ge didnt want to, oh well.
Reason 7, Elektronika EM 25, Korg EX-800, Arturia V-Collection, Komplete 9, G Force String Machine,
synthmaniak
Postby synthmaniak » Fri Mar 07, 2014 9:55 pm
sam wrote:I have fixed a few of these....The battery needs urgent replacement and those switches are hard to fix plus many other connectors go bad inside....Sounds ok but the lack of parameter control is a killer.
i wont, thank you.
synthmaniak
Postby 2manydrummachines » Fri May 09, 2014 12:45 am
synthmaniak wrote:ok so i talked him down to $280 but ge said it needs a cleaning, some of the keys need to be pressed on a bit harder than usual.
Did you get it? I like that one.
2manydrummachines
Postby Rezisehtnys » Fri May 09, 2014 6:31 am
As far as inexpensive analogue poly synths go the Roland JX and Alpha Juno series is where it's at. The biggest drawback to me with the Poly-61 is the incredibly small resolution on parameters. Ehh, not fully analogue but the KORG DW8000 is a good inexpensive vintage unit.
Rezisehtnys
Real name: Casey
Gear: Ensoniq VFX
KORG Monotron
KORG Triton
Peavey Fury 1992
Peavey KB-300
Peavey Milestone 1984
Roland JX-8P
Waldorf Micro Q
Yamaha KX5
Yamaha SY77
Postby recordbot » Fri May 16, 2014 3:30 pm
I have a broken one I found on the street you can have for the shipping and payment processing costs,
thought I could fix it up pretty easy, was definitely wrong, I've fixed a lot of things but this board is just a pain to work on, the battery acid leak problem combined with the little plastic clips on the keyboard pcb make this a giant hassle,
I can get sounds out of it and think it sounds cool,
if you get a good one you could use it for parts, the joystick is broken missing the left right mechanical parts
also make sure all the keys work, test all parameters and shake the thing up to make sure there aren't loose battery acid bits flying around inside that will short something out once they hit the right spot, probably just after you pay for it and get it home.
recordbot
Postby Aaron2 » Sun May 18, 2014 7:27 pm
The Poly 61 was my first "real" synth, so I've got a soft spot for it. You'll never get the guy down to $125, as one poster suggested. In the post-eBay age, no one is giving away synths for that price anymore. Even a non-working Poly 61 in halfway decent shape will sell for $200 on eBay. At least the one you're considering is mostly functional.
If you buy this synth, you should plan on spending a couple of hundred bucks to get get it fully inspected, get the battery changed, the key contacts cleaned, and to possibly replace other faulty components. Once you're done, though, you'll have a very nice, working vintage synth.
Just make sure to figure repair costs into your buying equation.
Aaron2
Real name: Aaron
Gear: Pioneer: Toraiz SP-16
Elektron: AK, AR, MnM, MD, OT
DSI: Evolver, MEK, P08, Pro2
Korg: Arp Odyssey
Waldorf: Blofeld Keyboard
Postby 2manydrummachines » Thu May 29, 2014 7:17 pm
So did you ever buy it?
It is a cool synth. If you don't have a Kenton ProSolo to sync it up you can always sample it.
2manydrummachines
Previous
Return to Buyer's Guide
