Question about Novation Ultranova & Roland Gaia
Antimatter
Post by Antimatter » Thu May 29, 2014 1:06 am
I'm split on whether to buy the Novation Ultranova and Roland Gaia. The one feature I really need is the ability to play, let's say the bass line of a song, save it, then play the lead over the bass, both at the same time.
Do either of these synthesizers have that capability, and if not, is there something I can hook up to the synth (besides a computer/laptop) to give it recording/playback capability?
Thanks.
Real name: Unpronounceable
Band: Eridani V
Re: Question about Novation Ultranova & Roland Gaia
Post by Ashe37 » Thu May 29, 2014 1:07 am
you're looking for a 'sequencer'.
Antimatter
Post by Antimatter » Thu May 29, 2014 1:24 am
Ashe37 wrote:you're looking for a 'sequencer'.
Yeah, that's the word for it. I'm guessing neither the ultranova nor the gaia have a built in one, so what are some recommended (inexpensive) sequencers that will work with them?
EDIT: Found this site, but you have to pay to see the video.
http://maschinetutorials.com/novation-u ... /#comments
Band: Eridani V
Post by Ashe37 » Thu May 29, 2014 1:42 am
cheapest sequencer is going to be a midi cable to your PC and a daw like REAPER. Keep in mind you'll run out of polyphony on your synth tho, *if* it is multutimbral.
Post by Stab Frenzy » Thu May 29, 2014 1:59 am
Neither of those synths is multitimbral (unless you count the GM section on the Gaia, which you shouldn't) so if you want to do what you're saying you need to record the audio from the output to a DAW (or looper, or hardware recorder) before you change the patch and play the next sound.
Antimatter
Post by Antimatter » Thu May 29, 2014 2:19 am
Stab Frenzy wrote:Neither of those synths is multitimbral (unless you count the GM section on the Gaia, which you shouldn't) so if you want to do what you're saying you need to record the audio from the output to a DAW (or looper, or hardware recorder) before you change the patch and play the next sound.
Okay, thanks for clearing that up. Would you recommend any good hardware loopers/recorders that will work with the Ultranova and Gaia?
Post by Stab Frenzy » Thu May 29, 2014 4:21 am
The Elektron Octatrack would be a good choice. Can sequence the UN over midi too. I use those two together and they're great.
madmarkmagee
Gear: King Korg
ESQ-1
Reface DX
Microbrute
Shruthi-1
Pittsburgh System-1
Juno 106 (needs work)
Post by madmarkmagee » Thu May 29, 2014 6:07 pm
The Gaia has a phase sequencer (google it for more info). You could record a a sequence, then play it back, and play over it, with out any external hardware. However the Gaia is not mult-timbral. That means that say I have a brass patch, I can play a brass bass and a brass lead, but couldn't do a brass bass and a string lead.
