Minibrute+Blofeld for ambient sounds. Would that work?
Ambiente Inóspito
Post by Ambiente Inóspito » Tue Jul 07, 2015 3:14 pm
So this is my first post here and I'm also new in the world of synths. I'd like to make ambient sounds just for fun. I don't even intend to show these to other people.
From my research, I discovered that I need a synth with post-processing capabilities (is that right?) and got recommendations of a Minibrute + Waldorf Blofeld or an Access Virus.
What do you guys think about this? I plan to spend some good time to learn and dedicate to these things and my budget, ideally, is 800 to USD 900.
Thanks for all your help and for reading this.
Re: Minibrute+Blofeld for ambient sounds. Would that work?
Post by meatballfulton » Tue Jul 07, 2015 4:35 pm
With either a Blofeld or a Virus you don't need a Minibrute at all to create ambient sounds.
If you were thinking of using those synths just to process the miniBrute with their effects you'd be better off just buying a good effects processor.
Ambiente Inóspito
Post by Ambiente Inóspito » Tue Jul 07, 2015 8:58 pm
Thanks for your answer.
Which one would you recommend given my conditions?
Rick N Boogie
Real name: Alan
Basses/synth fx galore
Band: no.one.won
Post by Rick N Boogie » Sun Aug 02, 2015 10:27 pm
Either a Blofeld or a Virus would work well. Generally, an older Virus, B or C, are more affordable, but either one will provide all the sounds you seek, and then some.
Bassist, synth junkie
ryryoftokyo
Real name: Ryan
Band: Tarot Sync
Post by ryryoftokyo » Tue Aug 04, 2015 5:14 pm
The Blofeld is an ambient machine. As for the Minibrute, it seems like unless you're going to run it through heavy effects, it seems a little silly. For the same money, you could buy another Blofeld and have two ambient machines.
Psy_Free
Gear: Synths 'n' stuff.
Band: Klangzeit
Post by Psy_Free » Tue Aug 04, 2015 7:45 pm
For ambient I would recommend the Blofeld & forget about the Minibrute. You will need some outboard effects though as the Blofeld's are pretty awful (IMO).
Given your budget you might want to check out a Boss VF-1 (2nd hand) as a decent all round multi-effect processor. Can be had pretty cheaply & cover many bases effect-wise.
Bandcamp 1
Bandcamp 2
Soundcloud
