What poly-synths can have separate envelopes per voice?
Brik
Post by Brik » Fri Jan 27, 2017 7:16 pm
For complex, evolving pad sounds, where each voice is different -- what polyphonic synthesizers can have separate envelope controls and values per voice?
I am thinking along the lines of like the Oberheim Four and Eight voice, or an Alesis Andromeda (in Mix Mode -- each patch in the mix can have it's own envelopes and patch settings)
Do any of the other Oberheims have the ability to have fine grained control over each voices envelopes? Omega/Code 8? Voyetra?
Cheers!
Hubaswift
Re: What poly-synths can have separate envelopes per voice?
Post by Hubaswift » Fri Jan 27, 2017 8:09 pm
I believe the Xpander allows this, and allows you to treat each voice as a separate synth. I'm not 100% sure if each voice would then require a separate gate and pitch input though. Worth looking into. The Shear Electronics Relic-6 synth (an Oberheim-X remake I believe) has controls to vary the envelope, pitch, and stereo field slightly between voices, but does not allow complete control over each separate voice.
Post by Stab Frenzy » Fri Jan 27, 2017 11:57 pm
DSI tetra does, depending on which mode you're in.
Baus
Post by Baus » Sat Jan 28, 2017 12:22 am
Not in the Oberheim category but,
The Ensoniq ESQ-1 has three oscillators each with it's own DCA.
Each DCA can be assigned to have it's own ENV
It has 4 Envelopes of which ENV4 is hardwired to DCA4: the Final Volume
It's an 8 Voice Polyphonic synthesizer so if you layer two sounds you have a 6 OSC sound that is 4 Voices Polyphonic with 2 individual Analog Filter Envelopes at work as well.
Brik
Post by Brik » Sat Jan 28, 2017 4:59 am
Thanks for the replies everyone -- and Its ok if its not in the Oberheim category!, I am curious which hardware synths have this flexibility in general :)
I see ESQ-1's for sale alllll the timeeeeeeee in my area on Craigslist, interesting! Ill have to give these a second look.
EDIT: Oops, while were on the topic of Digital Synths, of course the DX7 and other FM synthesizers have this ability to edit the individual operator envelopes as well :) But do any analogs?
Brik
Post by Brik » Sun Jan 29, 2017 5:49 pm
Surly there has to be more?!
Post by Stab Frenzy » Wed Feb 01, 2017 7:17 am
With a midipal you can just chain whatever synths you want together to do this.
Yekuku
Post by Yekuku » Sun Feb 05, 2017 11:32 pm
Vermona Perfourmer in poly mode has seperate envelopes per voice but is not a polysynth.
It is all about sharing...
JeEA
Post by JeEA » Sat Feb 25, 2017 1:55 pm
Akai timbra Wolf allows 4 different sounds so chords Can have
individual sounds for each jet if that is what You mean.
It is a 4 voice analog synth with different voice config and sequencer
It Can be 4 mono sounds on different midi channels as Well.
The esq-1 Can not do that however akais synth engine i rather small
Cheers
Jens
Post by meatballfulton » Sat Feb 25, 2017 2:48 pm
Yekuku wrote:Vermona Perfourmer in poly mode has seperate envelopes per voice but is not a polysynth.
It is a polysynth in poly mode. It's just like the Oberheims, multiple mono synths tied together for polyphonic operation.
Each voice is simple: one VCO, one VCF, one VCA, one LFO and one EG...much like an SH-101. Not only does each voice have it's own EG, each voice can be totally different...VCO waveform, pitch :shock:, filter and LFO settings. This is not too useful for normal polyphonic playing but when the Perfourmer is driven by an appegiator it gets pretty wild. In fact, it's impossible to get each of the four voices to sound 100% identical the way most polysynths do.
ninja6485
Band: Subliminal Sea
Post by ninja6485 » Sat Feb 25, 2017 5:09 pm
The Fizmo can have 2 independent voices per part, and has 4 parts that can all have their own envelopes and settings. I never find that it needs more than one or two though, as it's easy to get carried away and program something odd!
Ncapone
Gear: Roland V-Synth
Moog Sub 37
Korg EMX-1
Crumar Performer
Dave Smith Instruments Prophet 08
Band: Terrapin
Post by Ncapone » Tue Feb 28, 2017 4:45 am
I suppose the Roland V-Synth might fit in this category if you set up a unique zone per key.
pflosi
Post by pflosi » Tue Feb 28, 2017 1:35 pm
Brik wrote:an Alesis Andromeda (in Mix Mode -- each patch in the mix can have it's own envelopes and patch settings)
Ncapone wrote:I suppose the Roland V-Synth might fit in this category if you set up a unique zone per key.
That's not the same on the A6 and V-Synth (and tons of other synths), what they do is split (and / or layer) keyboard zones. That will give you different settings for different zones of the keyboard, but you cannot set them up per voice.
Brik wrote:of course the DX7 and other FM synthesizers have this ability to edit the individual operator envelopes as well :)
The individual operators, yeah, but that's part of the "synthesis engine" and also not different voices.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Tue Feb 28, 2017 7:23 pm
Roland D-50, because every sound can be made up of 4 "parts", each part being its own set of oscillator, LFO, envelopes and filter.
Newer synths, the Yamaha Motif XF for instance. Has 8 separate "minisynths" that can be combined in each sound.
pflosi
Post by pflosi » Wed Mar 01, 2017 1:47 pm
^ Both of these examples are also splitting, resp. layering, and not assignable per voice.
