Massive AMS RMX 16 Reverb Impulse Response Library from Townhouse Studios (Peter Gabriel, Kate Bush...)
matia
Real name: matia
Gear: Forum said that I exceeded 150 characters. Here's a partial:
Serge Modular 9 pannels SMS Modular almost all modules
ARP 2600
Roland Tr 808 ....
Post by matia » Mon Jul 29, 2019 8:16 am
A little while back I shot out and programmed Townhouse Studios AMS RMX 16. This was the same unit used on many landmark records by Kate Bush, Peter Gabriel, Phil Collins and others. It took ages to edit everything and organize all the assets but now it's complete and I can present to VSE a whopping 194 individual impulse responses of the AMS RMX 16.
Unlike other attempts, each decay time has an associated EQ setting, because the onboard RMX 16 drastically changes the reverb tails and overall tonality. With this library, you can now correctly model the distinct behavior of the RMX. Every reverb algorithm was sampled and everything is organized in a simple to read naming scheme to make loading impulses a breeze. This library will work with ANY convolution reverb that can load stereo wav files (Space Designer, Space, RV7000, Revolver, IR1 ...).
It's available now at:
https://inhalt.bigcartel.com/product/to ... -responses
A quick drum sample and official copy below:
• 194 individual impulse responses of the AMS RMX 16.
• Multiple EQ settings sampled for each decay time.
• Impulse responses of every AMS RMX 16 reverb algorithm including the legendary NonLin gated drum reverb // Ambience, Plate, Hall B3, Hall C1, NonLin 2, Room A1, Chorus 1.
• AMS RMX 16 sampled comes from Townhouse Studios and is exact unit used on classic records from Peter Gabriel, Kate Bush, Phil Collins and many more.
• Compatible with ANY convolution reverb (Logic’s Space Designer, Ableton’s Convolution, Reason RV7000, Avid’s Space, and any convolution reverb that can load impulse response wav files).
• Instant download.
Rhys Fulber (producer Fear Factory, Front Line Assembly, Delerium):
“Transport yourself to that glorious era of patching the AMS up on the SSL. This impulse library is as close to the real thing you can get.”
Audio Demo:
https://soundcloud.com/inhalt-1/townhou ... -drum-demo
Introducing the Townhouse RMX by INHALT: the most comprehensive impulse response library of the legendary AMS RMX 16 reverb processor from a very legendary studio. Townhouse RMX features 194 expertly sampled impulse responses of every major algorithm of the RMX 16. Unlike other impulse responses of the AMS, Townhouse RMX features various onboard EQ settings for each decay time. The RMX 16 drastically changes its decay and reverb characteristic depending on the EQ settings of the onboard low and high EQ, so we sampled each decay time at numerous EQ settings for a deep and detailed representation of the legendary reverb.
The AMS RMX 16 we sampled comes from the infamous Townhouse Studios. Townhouse Studios was originally built by Richard Branson to be the hub of Virgin Records. This very unit was used on breakthrough records from Peter Gabriel, Kate Bush, Phil Collins, Duran Duran and many other major recordings from the 80s and 90s. Interestingly, the AMS itself, with its legendary NonLin setting was designed to emulate the gated drum sound developed at Townhouse on Phil Collins’ “In the Air Tonight”.
Compared to the actual hardware, these impulse responses, to our and the ears of other major producers, exude the realness, depth, and three dimensionality better than DSP emulations of the RMX. During critical listening tests conducted in several major recording studios (with real AMS RMX 16s in the fx rack), we were throughly impressed with the accuracy of the impulses in completely capturing the unique sound of the RMX 16.
The impulse response library is organized in an easy to read manner and all relevant information is in the file name itself. For example, Plate_0.1s_-2L-2H.wav let’s us know instantly that it’s the Plate algorithm, at a .1 second decay time with a -2 setting on the Low EQ and a -2 setting on the High EQ. Because of this organization, it’s very quick to find the exact setting needed, just like punching the big square buttons on the actual AMS RMX itself.
This is an instant download.
Online
Re: Massive AMS RMX 16 Reverb Impulse Response Library from Townhouse Studios (Peter Gabriel, Kate Bush...)
Post by meatballfulton » Mon Jul 29, 2019 12:43 pm
Wow. Thanks!!!
matia
Real name: matia
ARP 2600
Roland Tr 808 ....
Post by matia » Mon Jul 29, 2019 7:07 pm
my pleasure
Wow. Thanks!!!
matia
Real name: matia
ARP 2600
Roland Tr 808 ....
Post by matia » Wed Jul 31, 2019 10:02 am
Here's a long demo of many of the algorithms.
