App for converting SF2 to WAV or similar?
Is there a program available for splitting soundfonts into WAVs or is there a VSTi or Standalone app that can use soundfonts?
MFB Synth Lite II, x0xb0x, ER-1 Mk.II, Yamaha TG-33, Axiom 49
- elmosexwhistle
- VSE Review Contributor
- Real name: Alex
- Band: Elmo Sexwhistle
there are quite a few free soundfont player vst's out there, i've never used them myself but i'm guessing they do the job, just google it...also, remember Kontakt and Halion can import soundfont files...x
- Bitexion
- Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Soundfont files usually contain lots of multisamples, so it's not as easy as just convert it to a single wav file.
But with players like Kontakt you can load them up and play the sounds as they are intended. You get SF2 files containing the complete DX7 soundbank, vintage synth collections etc, all sampled and layered across the keyboard when you load them up. So converting it to a single wav file would be useless.
I am sure there are tools out there that lets you extract all the wav files from a SF2 file though. But you'd have to do the job of layering them yourself, then.
Usually, to best represent the original sound, it is sampled from many points of the keyboard. Then all the WAV files are put in a directory, and they are assigned to different zones on the keyboard, so when you play from C0-C1 you get sample1.wav, from C1-C2 you get sample2.wav etc. This is so you won't get the usual timestretching when you change pitch of a single sample. The SF2 files have little index files that automatically place the samples in the correct keyzones for you.
I don't know the name of any free SF2 player, but I guess they are out there. I use a commercial one so I don't need them.
- No Longer Registered
SF
There is a Windows program that can convert SoundFonts to Wav files, but the installation program is in German. I forget what the name of the program is. I thought it would be cool, but all of the Wav files it created were only a few milliseconds long. Apparently the waveforms are looped and controlled with envelopes otherwise, they would just be tiny blips.
- Big Gnome
- Gear: E-mu Proteus 2500
Ensoniq ESQ-1
Ensoniq VFX
SCI Prelude
Waldorf Blofeld - Band: The Nondescript
The sampler in Logic can convert soundfonts to their component wavs + the exs instrument definition. If you have a few soundfonts you're really dying to convert, I'd be happy to help you out.
Some of my c**p
Some of my c**p
- gmeredith
- Band: Warning Will Robinson
The program is called Xtrakk:
http://homepages.compuserve.de/murmel99/software.htm
It works well, I've split up sf2 files that had several sounds in them okay.
Cheers, Graham
Cheers, Graham
- elmosexwhistle
- Real name: Alex
it's called Awave studio and it works a treat! you can download a shareware version which is fully functional! im currently converting sf2 files to akai 1st gen files with it...because my a3000 can read them! SCORE! x
- Thefumigator
- Real name: Amalfi
- Band: thefumigator
Re: ...
Finally! you were messing around with this problem for several weeks i believe...elmosexwhistle wrote:it's called Awave studio and it works a treat! you can download a shareware version which is fully functional! im currently converting sf2 files to akai 1st gen files with it...because my a3000 can read them! SCORE! x
watch my first youtube video
-We're gonna die, you know.
-Maybe. But if we die, we're gonna die walking.
- elmosexwhistle
- Real name: Alex
i was, just waiting for a scsi lead now so i can hook up a cd rom drive to it and transfer programs like crazy shiz
x
