Pro tools question
DX
Pro tools question
Post by DX » Fri Oct 27, 2006 3:29 pm
Hi.
Misteriously, grid has dissapeared on Edit window. I don't remember I have touched any button.
All the sessions have the grid missing.
I work with PT for two years, never happened this. Sure it is or a silly fault from myself, or maybe the program neeeds to reinstall.
Any suggestions?.
Roland Promars, E-mu EMAX and some other machines...
bigbadbarns
Post by bigbadbarns » Fri Oct 27, 2006 3:52 pm
I don't usually use pro-tools, and don't have it on my computer, but a couple of thoughts.
Does the grid disappear when you put it into slip mode? If so, maybe just press 'grid' in the top left hand corner (IIRC). Does PT have a 'view' menu? If so, is there a 'grid' option? If so, is it checked?
Sorry, hope someone can come along to help you.
DX
Post by DX » Fri Oct 27, 2006 7:40 pm
hi big, thanks for the input.
As I remarked in Help forum (I also post there), problem is fixed.
Yes, first of all I was looking for any option in View menu related to grid. Also I checked Grid button was on instead Slip or another grid option.
After all these checks, I decided to reinstall the prog, using the Repair Option, which reinstall everything, taking care of your settings, but, problem still was there.
So I started to check every little checkbox in all Options/Setup menus and submenus. Then I found "Show grid in edit mode" disabled.
What I am concerned is about I never disabled that parameter since I worked last time (yesterday). I am considering that maybe I pressed a keyboard combination (like CNTRL + any other key) which disabled that,.
The right thing is now I can see the grid :)
Thanks!
tallowwaters
Gear: LC-MS/MS
Post by tallowwaters » Fri Oct 27, 2006 9:34 pm
i will help this right on into SOFTWARE
