Software Studios
- stephen
- Gear: Laptop
House Brick
Renoise
Loomer Aspect
FM8 - Location: UK
Software Studios
A question (or two) for all you software-based fans...
What midi controllers do you use with your softsynths? Do you combine your setup with hardware synths or are your purely software-based?
Stephen(2)
- Stab Frenzy
I use my V-Synth as a midi controller. Obviously then I use hardware with my software as well.
I think using hardware effects with software synths is a great way to get interesting new sounds. One of my favourite combos is to run a softy out through an analogue delay then cranked through my valve channel strip. There's no way you could tell it's software after that.
- Real name: Tyler
- Gear: I don't even remember half of it
- Band: width full
I have a dedicated USB MIDI controller (Evolution Mk-461c), but I'll also plug a Sequentix P3 into a MIDI interface.
I combine hardware and software...which has been the source of some frustration, but usually it's no trouble to run both.
"I thought all you did was push a button and sounds came out!" - Mom on synths
"Not quite, Mom." - Me on synths
- krushing
- Real name: Petteri
- Gear: Doepfer Dark Energy, Nord Lead 3R, Waldorf MicroQ, Acidlab Bassline 3, Roland TR-606
- Band: Salaneuvosto
My setup's shrunk into just a puny M-Audio Oxygen8 controller + software synths - synth-wise that is. I've sold off the Juno 106 & the TX81Z and my Nord Electro & Korg EX800 are residing in our practice space elsewhere. Couple of hardware effects, acoustic instruments and all that, but synths are all in the box now.
- stephen
- Gear: Laptop
House Brick
Renoise
Loomer Aspect
FM8 - Location: UK
Hi all,
I use my trusty 'ol microkorg as a controller for my laptop. Indeed I'm using it right now to try out a couple of newly installed softsynths. My wife has a Yamaha home keyboard which was out on loan to someone. When we finally got it back I discovered it has midi in/out so sometimes I use that as my controller so the korg can get on with the job of being a synth
Stephen(2)
- drawtippy
- Band: Draw Tippy
I use an M-Audio Axiom 61 to control my softies. It also can be used to sync hardware as well, since it has an additional midi in/out (besides it's USB connection to the computer). It also has drum pads! For softies I use NI Komplete 4, Zebra2, Quadrasid, BFD, Phillharmonic and more.
Then I have my hardware synths. Which get sent midi info from my MOTU, although the axiom could do this as well. I like to get a synched pulse bass going on my Voyager and then add a synched arpeggio on my JP-6 over top. It's also cool to record a midi part with any old sound and then send it to one of the hardware synths with midi. This way, you can build complex, perfectly timed and played synth parts and then send them to an analog and record them back into the DAW.
I admit that hooking these vintage beasts into midi can be complex. Some, like my Maxi Korg, aren't even hooked in at all. When some of the softies I have sound so great, why would I go through all that hassle? Well that's a totally different thread but I try to use I blend of hard and soft.
- mono/noise
I use a M-Audio Radium 49, planning on replacing it with a Axiom 61 soon or maybe the new Akai keyboard thing if they release a 61 key version.
www.myspace.com/mnoise
Gadgets: Pulse+_Opera 6_Jen SX1000_microKorg
Xbase 09_SK-5_CZ-3000_ESQ-1_Electone A-55_Theremin
Cracklebox_Thingamagoop_Game Boy( LSDJ )_KP3_MPD24
Tascam Porta 07_Multimix 12_Logic Studio_Live 6
- redchapterjubilee
MIDIman Oxygen-8 2-octave controller w/USB out to the laptop. Using an Echo Indigo I/O to handle latency. My music is about 1/3 software and 2/3 hardware.
