Increasing Computer's Processing Speed? to run more VST
PaulRice
Gear: Roland Juno 6
Roland Jv-880
Yamaha dx27s
Yamaha QY100
Post by PaulRice » Tue May 15, 2007 6:41 pm
Hey, its been awhile since i posted here.
Lets start off, Im in love with my computer and i dont want to replace it. Sadly, when i load multiple VST's or effects in FL STUDIo. I keep getting this VIBRATING/SKIPPING sound. I know it has somthing to do with the cpu usage. I was wondering if theres a way i can fix this problem WITHOUT buying a new Computer? Is it true they sell cards that you can install to fix this problem?
-Paul Rice
maindeglorie
Gear: Voyager Select,Little Phatty,ARP Solus,Omni II,Yamaha CS-40M,Prophet 5,Prophet 08,OB-Xa,MaxiKorg,Nord Lead 3,Nord Wave,Eurorack modular, etc.
Try adding more RAM.
Post by maindeglorie » Tue May 15, 2007 6:45 pm
It did the trick for me. Adding RAM that is.
chamomileshark
Post by chamomileshark » Tue May 15, 2007 7:34 pm
I'll second the RAM suggestion. I don't know FL but does it have a freeze function?
kk994
Post by kk994 » Tue May 15, 2007 8:15 pm
Sometimes RAM is not the only answer. If your processor is maxed out then that's your lot. You could try overclocking but I don't know much about it.
You could turn off all network c**p, virus software all that kind of stuff.
If you have a very small amount of RAM then more will benefit but just make sure it's the RAM and not your processor thats crapping out. No pint in spending money on RAM if it's not going to help..
otto
Post by otto » Tue May 15, 2007 10:26 pm
kk994 wrote:Sometimes RAM is not the only answer. If your processor is maxed out then that's your lot. You could try overclocking but I don't know much about it.
FL and CTRL+ALT+DEL ought to give you some idea of what is being taxed. My CPU was not good enough but I had more than enough meemory for what I was doing.
hello darkness, my old friend
Gothboy
Gear: NordLead 2, Nord Micromodular, Novation Nova, Roland D-50, Alesis QS-6, Roland D-2, Yamaha A-3000
Band: Dymaxion Vehicle
Post by Gothboy » Tue May 15, 2007 10:55 pm
Let's start out again. How powerful is the computers' cpu? Also, max out the computer with the most RAM it can take, as it's been said.
Tidda
Post by Tidda » Tue May 15, 2007 11:10 pm
So, what's your current configuration. In particular, CPU type and speed, amount of memory and what OS?
That woud give us some idea on what could be improved upon.
Tidda
