New to softsynths
- thestreets
- Gear: Maschine Mikro, Electribe ESX, KP3, Korg R3, Microkorg.
New to softsynths
I am just getting into soft synths. I am going to buy absynth. Loved the demo, just what i was looking for. Let's just say that i have none of the necessities for softsynths...what would i need? I probably already have some of the necessary items but just give me list and I'll check off the ones i have.
Thanks
Thanks
- thestreets
- kernelkurtz
what do you mean what would you need? as long as you have a soft synth and a midi keyboard to plug into your computer, you're set.
for playing live, i have a usb interface (m-audio mobilepre) which i then hook up to a monitor/amp to get the best sound.
AAS Lounge Lizard, String Studio; Arturia ARP2600V, CS-80V, minimoogV; Cakewalk Rapture; GForce impOSCar; Linplug Octopus; NI Pro-53; Rob Papen Albino 3, Predator; u-he Zebra2; Waldorf Edition
- braincandy
- Retired Moderator
- thestreets
- Thefumigator
- Real name: Amalfi
- Band: thefumigator
you'll need a couple of beers..., and just run absynth, let it know which sound interface to use, and enable midi in. that's all unless you want to use a VST host, to build/track a complete tune.
watch my first youtube video
-We're gonna die, you know.
-Maybe. But if we die, we're gonna die walking.
- viscerallove
a keyboard midi interface is something that will plug into your computer through your USB port and allow you to control and play Absynth. depending on what you get (a small list is below, but there are many others out there), you will have a certain number of knobs and sliders that you can assign to various parameters on absynth so everything doesnt have to be click and drag.
M Audio Oxygen8
Novation ReMOTE
Edirol PCR-50
some keyboard midi interfaces also have audio interfaces built into them. these will allow you to plug mics/instruments in and record through it instead of your onboard computer soundcard. the upside to these is that they usually have lower latency than most onboard soundcards. lower the lower the latency you have, the shorter amount of time it is going to take for absynth to make a sound after you push a key on your keyboard. something like this is the M Audio Ozone
the Novation X-Station is a midi interface, audio interface, and has a synth engine built in.
if you dont want to have a keyboard as a dedicated controller, and you would rather just use your Micron, something like the M Audio Uno will allow your micron to control absynth.
hope that helped!
M Audio Oxygen8
Novation ReMOTE
Edirol PCR-50
hope that helped!
- thestreets
You should read some of the lessons over at tweakheadz..
It's a great resource to anything you want to know about how to set up your gear - and much more.
It's well written, fun and interesting
http://www.tweakheadz.com/guide.htm
HrBak
HrBak
- thestreets
- thestreets
- Stab Frenzy
- crystalmsc
- Band: Crystaline
and it even have a template for the Absynthviscerallove wrote:the Novation X-Station is a midi interface, audio interface, and has a synth engine built in.
it will not be as intuitive and enjoyable as using a dedicated controller.thestreets wrote:I want to have my micron control absynth and assign the pitch bend and sliders to parameters.
you can feed the amp with the output of the X-station (playing Absynth sound or the internal Novation engine!) and feed the output of the amp to the X-station in and record to your PC through USB or digital out. I also really like the distortion on this synth, you can process the audio input using this nice distortion along with other fxs. It even have phantom power for your condenser mic to record some vocal.thestreets wrote:I want to be able to put absynth through an amp or record into my hardware recorder. Those are really the necessities. Which of those you listed would i need to get for this?
again, something like the above would be nicethestreets wrote:What kind of interface box would i need to record absynth into my hardware recorder?
Kaossilatron - Voicillator
You can just use your computer's built in soundcard. Make sure you install ASIO4All drivers and use those. IF you don't there will be a latency from the time you press a note on your keyboard and audio is streamed to the sound card.thestreets wrote:What kind of interface box would i need to record absynth into my hardware recorder?
If you want some better quality stuff, get an simple USB audio interface (a.k.a. sound card).
But then again, why the h**l would you want a hardware recording interface? You have a computer with a hard drive, which can record things... = it is a hardware recorder by itself :p
