making Reason lo fi
ned-ryarson
making Reason lo fi
Post by ned-ryarson » Thu Jun 14, 2007 3:38 pm
is there anything i can do in Reason to make the synths or drums there sound a bit lo fi?
cheerz
hearttimes
No Longer Registered
Post by hearttimes » Thu Jun 14, 2007 4:32 pm
try running the main outs through the scream unit first. think they even have some presets for drums.
hematurge
Gear: PC , Axiom 25, Roland SP-404, Zoom MRT-3, Boss DR-660
Band: the hematurge
Post by hematurge » Thu Jun 14, 2007 7:08 pm
Can also reduce the sample rate in the soundcard preferences.
This is my signature. There are many like it, but this one is mine.
Shleed
Real name: Ashley Dolan
Gear: Doepfer A100
MFB Synth II
Korg MS20 Mini
Ensoniq EPS-16+
TT303
TX81Z
Band: Shledge
Post by Shleed » Thu Jun 14, 2007 10:26 pm
Bit. Crusher.
luciano
Post by luciano » Mon Jun 18, 2007 11:54 am
Also taking away a bit of highs, (or bandpassing if you don't need much low end) can help. And lowering the pitch a little, but not too much if you don't want them too messy. You can also try to put a scream 4 with the tape algorithm after the reverb that you will use on drums, but be subtle, it's easy to make a lot of noise this way.
"I don't play a lot of fancy guitar. I don't want to play it. The kind of guitar I want to play is mean, mean licks." John Lee Hooker.
http://www.myspace.com/brainl
http://www.myspace.com/dogadog my Punk/garage band
crystalmsc
Band: Crystaline
Post by crystalmsc » Mon Jun 18, 2007 1:51 pm
browse around here, and try this great Vinyl based vst.
Kaossilatron - Voicillator
HrBak
Post by HrBak » Mon Jun 18, 2007 11:02 pm
Just play around with an equalizer
Letters and Leaves of Grass
Check The winter leaves at:
******* www.myspace.com/vickystudio *******
Bross
Post by Bross » Mon Jun 18, 2007 11:44 pm
Try a tiny bit of random LFO on both oscillators for an old tape/drift effect. Also tune the oscillators off center e.g. osc1 +2 cents and osc2 +4 cents instead of osc1 -1 cents osc 2 +1 cents for an out of tune analog feel.
luciano
Post by luciano » Tue Jun 19, 2007 4:51 pm
To avoid confusion, when I said lowering the pitch I intended on drum samples or breaks.
nogginj
Post by nogginj » Tue Jun 19, 2007 5:12 pm
record it to cassette tape, undo the tape, play with it, drop it in the dirt, reassemble.
lots of work but you pay for what you get.
-j
the great escape
Gear: Nord lead 2x, roland Tr-707, roland R8, Moog prodigy, delay, distortion, optigan, ace tone, cheap mic.
Post by the great escape » Mon Jul 09, 2007 6:01 pm
I sample lots of my reason beats into my sp-202 and then drop them back into the sequencer. I usually leave happy.
Nord G2X,Roland R8,Moog prodigy,Nord lead 2x,sp-404,sp-202,Laptop,stomp boxes
shaft9000
Real name: Dave
Band: moneymoneymoney
Post by shaft9000 » Mon Jul 09, 2007 7:56 pm
parametric EQ + distortion
