I have always wanted a Mellotron.
Tired of PC's after 20 years, I went and bought an iMac. Fabulous!
But then I found the GForce MTron software.
Got it, bought an Edirol 61 key, loaded all of it, and I am flipped at how cool this all is!
50+ voices, including some real WONDERFUL lo fi stuff.
And there is just nothing like a Mellotron sound! 99 Euros delivered.
They even have an attack and sustain setting, which makes for even more interesting sounds. Farting around using GarageBand filters with the MTron standalone is what I am going to try next, but not sure, as this is the first ever software thing I ever did.
WHAT IS GOOD iMac recording software? I don't want something I have to spend 400 hours learning. I will likely push the output to my Tascam HD recorder anyway. Should I just USB the sound out to the Tascam 2488 MkII?
jpl
WooHoo! MTron is magick! But I need iMac/Tascam advice......
- jplavidfan
- Gear: AX60, Ion, VFX, MS2000, Poly 800 MkII, Privia, Juno 60, Motif 6 Loaded, MiniCompact, Kurzweil K2V3, Minimoog D, Mtron, Virtual Synth
MS2000 - Nord Lead - Alesis Ion - Juno 60 - DX7 - MG1 - VFX - MTron - Motif 6 w/PLG150AN - Poly800 Mk II - AX60 - Privia - MiniCompact - Yamaha DGX500 - Hiwatt Theremin
- jplavidfan
OK. so
how do I get GarageBand to pull in the MTron instrument so that it functions with all those sounds?
jpl
jpl
- oceanbourne
Re: OK. so
I don't have the MTron but do have other GMedia softsynths and what you need to do is be sure that the AU version of the synth (MTron in your case) is installed on your Mac then go into GarageBand and look under the virtual instrument track options (create a new virtual instrument track if you don't have one up yet) and look for the "Generator" pull-down menu. Then, look on that menu and find the MTron. After selecting it, go press the "manual" switch to the right of that menu and you can open the entire MTron console just like on the stand-alone.jplavidfan wrote:how do I get GarageBand to pull in the MTron instrument so that it functions with all those sounds?
jpl
I like GarageBand. I have Logic, also, but I am more a composer than into recording and hence don't care much about effects and such . . . GarageBand is great for putting all my ideas together and using the softsynths I love to do it. Also, you can recod external live audio which I often do. Most of my tracks on GarageBand will be Absynth, Massive, Kontakt, ImpOSCAR, and external sound from the Triton and Nord Lead 2X.
Oceanbourne
http://www.myspace.com/faeroerne
Bösendorfer 170, Korg Triton Extreme 61, Roland Juno-G, Nord Lead 2X, Roland SH-201, microKorg, Ensoniq EPS-16+, Novation X-Station, CME-UF7 (for softsynths & Kontakt).
Oceanbourne
- synthetic88
The USB on the 2488 doesn't work that way. You can transfer WAVE files back and forth, but it doesn't turn into an audio interface. You'd need something like their FireOne or US-122L.Should I just USB the sound out to the Tascam 2488 MkII?
Andromeda • Voyager • Super Jupiter + Programmer • TX-802 • Two GigaStudio PCs
http://www.jefflaity.com/studio
