ReBirth Museum: have any of you successfully acquired the so
MrFrodo
Real name: Eric
Post by MrFrodo » Sat Sep 22, 2007 12:21 am
Have any of you entered the online museum for Propellarhead ReBirth and successfully downloaded the software? If so, how did you manage it? I've tried it and failed.
http://cdbaby.com/cd/ebgordon
stephen
Gear: Laptop
House Brick
Renoise
Loomer Aspect
FM8
Post by stephen » Sat Sep 22, 2007 8:56 am
I managed it. It's a bit torrent download so you'll need suitable torrent software.
Unfortuntately I can't get Rebirth to work on my linux computer (using the wine libraries), so I can't comment on it :(
Stephen(2)
bandreject
Post by bandreject » Sat Sep 22, 2007 10:41 am
MrFrodo wrote:Have any of you entered the online museum for Propellarhead ReBirth and successfully downloaded the software? If so, how did you manage it? I've tried it and failed.
Simple create a account by providing your email. Use the instruction that they sand to you in the email after creating account. Log in. Download the rebirth torrent file (*.torrent). Open the torrent file with a torrent client, after few hours you should have fully working rebirth iso. Burn the iso on a cd, or run from a virtual cd program. From this point you can install rebirth on your computer. Remember that after the installation, whenever you run rebirth, you must insert the cd, or the virtual cd for authentication.
stephen wrote: Unfortuntately I can't get Rebirth to work on my linux computer (using the wine libraries), so I can't comment on it Sad
Reborn is back, free rebirth clone for linux. Works on suse, and I am successfully running it on fc4. Remember that it uses only the /dev/dsp driver, so if you have for example /dev/dsp1, then you have to make a proper link.
Against the waveshaper.
stephen
Gear: Laptop
House Brick
Renoise
Loomer Aspect
FM8
Post by stephen » Sun Sep 23, 2007 1:11 am
Yay! Just got it... and it's working too!
Stephen(2)
cartesia
Gear: Octatrack
Bass Station 2
Band: TBA
Post by cartesia » Sun Sep 23, 2007 3:26 am
Ive got rebirth, installed it. . but how do I create the disc image? there's no ISO file.. and it tells me i haven't inserted the cd when i try to run
ford442
Real name: Noah
Band: Noah Cohn
Post by ford442 » Sun Sep 23, 2007 6:10 am
i'm looking at it right here - rebirth_iso_installation.zip - inside that is rebirth_iso_installation.iso - did you get the torrent from somewhere besides www.rebirthmuseum.com ?
bandreject
Post by bandreject » Sun Sep 23, 2007 11:44 am
cartesia wrote:Ive got rebirth, installed it. . but how do I create the disc image? there's no ISO file.. and it tells me i haven't inserted the cd when i try to run
From where you installed rebirth? You probably "unpacked" the iso, and installed it from hdd. Some crackers should make a patch for the cd-detection (this time it wouldn't even me illegal that much). It is really annoying, when you run reason with rebirth through rewire, and must remember to have the vcd running (that are 3 programs to be opened for one song!).
cartesia
Gear: Octatrack
Bass Station 2
Band: TBA
Post by cartesia » Sun Sep 23, 2007 11:54 am
^ seems to have autounpacked when i downloaded it..
ford442
Real name: Noah
Band: Noah Cohn
Post by ford442 » Mon Sep 24, 2007 12:00 am
ok.. good.. :-)
Rebirth is the best!! i'm listening to it right now :-) song called Aura - one of my favs...
MrFrodo
Real name: Eric
Post by MrFrodo » Mon Sep 24, 2007 12:22 am
ford442 wrote:ok.. good.. :-)
I brought this up before. Can you use it for composing and producing outside the Acid, House and Rave realms?
ford442
Real name: Noah
Band: Noah Cohn
Post by ford442 » Mon Sep 24, 2007 7:07 am
well.. you can get a lot of variation by rewiring through cubase.. it's also possible to make your own rebirth mods - totally replace the drum sounds with your own samples..
the PCF filter can do some very interesting things..
wish i could help you get it installed.. are you stuck at the downloading stage? you need a bit torrent client - i recommend www.utorrent.com
rachaellee
Re: ReBirth Museum: have any of you successfully acquired the so
Post by rachaellee » Tue Jan 12, 2021 3:26 pm
Its still available on Archive.org.
https://archive.org/download/rebirthrb338
//Rae
