An uncomfortable question about Arturia CS80V...
- No Longer Registered
I can run the synth at different sample rates, 41100, 48000 and 96000. If I choose higher sample rate, the envelopes become faster and the overall pitch of the synth rises.
Which sample rate emulates the CS80?
That's odd and shouldn't happen afaik...
The only time pitch would change is if you have an audio sample recorded at one sample rate and then play it back at another sample rate without converting the audio.
Audio is timestamped with the sample rate it was recorded with. For example 48000 samples per second. If I change the sample rate to 96000 it would play twice as fast. Like a film that has been recorded at 24 frames per second being played back at 48 frames per second.
This shouldn't happen with softsynths as they calculate their vales in realtime. So if I play something at 96000 it should play as normal but have 96000 sample resolution. The same for 44.1....
If this isn't the case... then I'm stumped
- Synthaholic
- Expert Member
Your sound card may not support the higher bitrates, so set it to 44.1 and you should be good to go!
- krushing
- Real name: Petteri
- Gear: Doepfer Dark Energy, Nord Lead 3R, Waldorf MicroQ, Acidlab Bassline 3, Roland TR-606
- Band: Salaneuvosto
SoundBlasters have long been notorious for the fact that their sample rate is locked at 48kHz or something like that - or at least that's how it was still a couple of years ago. I don't if the newer Audigys are any different. But if this is the case, it might be that while you can theoretically choose a different sample rate in a program, the playback is stlil forced into the locked rate, which should theoretically be a transparent conversion but, well, sometimes isn't.
//edit:
this tidbit from the Creative forum, as I suspected: "creative asio drivers for the audigy 4 are locked at 16bits/48khz and 24bits/96khz."
//edit:
- Bitexion
- Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Has never happened to me, I have an M-Audio soundcard w/ analog ins/outs.
When you increase the samplerate, you should just get a clearer, deeper sound as a result, because you're "raising the ceiling" so to speak so less parts of the full sound spectrum are shaved off on the top and bottom.
But keep in mind, CD format is still 44.1Khz, so if you record something in 48/96KHz, and try to burn it to a CD, you'll get no result.
I believe I could hear the result even if I recorded to an audio cassete. Especially in the filter and resonance sound. Otherwise, what's the point of 96000Hz resolution?But keep in mind, CD format is still 44.1Khz, so if you record something in 48/96KHz, and try to burn it to a CD, you'll get no result.
My Arturia Modular sounds much clearer in the high end at 96khz and thats not just with the stuff thats theoretically above what you can hear. I think the extra processing helps the normal higher frequencies you can here tho it tends to be a little too CPU intensive on my PC for normal use.martinp268 wrote:I believe I could hear the result even if I recorded to an audio cassete. Especially in the filter and resonance sound. Otherwise, what's the point of 96000Hz resolution?But keep in mind, CD format is still 44.1Khz, so if you record something in 48/96KHz, and try to burn it to a CD, you'll get no result.
That's another issue... My PC can't handle 96KHz on sounds with long release and my computer configuration wasn't yet possible when the CS80V was out. The Soundblaster was there already, though
Ok, I have fought with the software for the last week and, I think, I'll call it a day. If I have to spend about £150 on a proper audio interface to make my CS80V do 96KHz, then I'd rather spent that money on BOSS Micro BR multitrack and steer clear from the PC before I run into problems with computer DAW, etc.
Re: An uncomfortable question about Arturia CS80V...
And you think it's the Audigy 4? Strange, I had (well, still have, but no desktop PC anymore to put it in, so it is in my closet) an Audigy 2 ZS Platinum, much older, and yet it supports 48000.. You would think that a newer model would support it as well.
- ninja6485
- Gear: Virus Ti, Jx-8p, Juno 60, Radias, Maschine, 101,303,606,707,727,808,909, odyssey, mirage, akai s5K/s2K/s1k, drumtraks, E6400ult, M1R, rx5, fizmo,d50
- Band: Subliminal Sea
These posts were from 10 years ago
