Axiom 25 Help
Gdan
Axiom 25 Help
Post by Gdan » Fri Dec 30, 2011 1:54 am
Hi im about to buy an m-audio axiom 25 and i want to be able to hook it up to my compter i currently have MASSIVE and FM8 on my computer along with ableton and fruity loops do i need any other software for it to work?
astroidmist
Re: Axiom 25 Help
Post by astroidmist » Fri Dec 30, 2011 3:07 am
I think it should work fine. By the way, is it a first, second, or third generation Axiom?
If you have trouble with it, try quitting the programs, plugging in to a different USB port and restarting the programs.
Also be sure to check out the M-Audio Community Forums for help. But people here can help you also.
I have an Axiom 25 (first generation) and it works OK with my VSTi's and DAW programs. The only problem I had is Image-Line/FL Studio stuff can only use one MIDI controller at a time even though other programs can use multiples. It might be a bug, but I don't know how to fix it, so I just use one MIDI controller at a time.
Also, be sure to download the PDF manual for your model of the Axiom 25 from the M-Audio website.
