amSynth and multiple instances
Postby briandc » Fri Mar 01, 2013 9:25 pm
AmSynth (for linux) can run multiple instances simultaneously, with very low CPU.
So, for example, from "just" two oscillators, I can get 10 oscillators running in less than a minute. Nice!!
Are there other synths out there that are designed with multiple instance capability?
brian
Have your PC your way: use linux!
LinuxSynths.com
amSynth on Soundcloud
briandc
Real name: brian
Gear: 3 Midi controllers and anything linux! :)
Re: amSynth and multiple instances
Postby Big Gnome » Sat Mar 02, 2013 3:41 am
Unless I'm misunderstanding your question, all of them.
Some of my c**p
Big Gnome
Gear: E-mu Proteus 2500
Ensoniq ESQ-1
Ensoniq VFX
SCI Prelude
Band: The Nondescript
Postby briandc » Sat Mar 02, 2013 8:20 am
Big Gnome wrote:Unless I'm misunderstanding your question, all of them.
True. But I don't see it "incorporated" into the synth structure, as a basic element of the synth itself. I've never even read anyone saying they run (x) number of this synth, (y) number of that synth..
And, it seems (theoretically) possible to get just about "any" sound imaginable when you have multiple oscillators, filters, etc.. Even "big" hardware synths that boast (x) number of features can't compete with running several instances of one softsynth.
Kind of like modular synths, I guess...
brian
LinuxSynths.com
briandc
Real name: brian
Postby tekkentool » Sat Mar 02, 2013 11:56 pm
Erm, you can run multiple instances of kinda anything software wise :?
Sylenth1 has a voices slider on each oscillator though. So it can go from 0-8 oscillators and there's the possibility of four main oscillators in each instantiation. This means it's possible to be running 32 oscillators per voice BEFORE unison.
I've run thousands of oscillators at once with sylenth1 before.
tekkentool
Real name: Steve
Band: none currently
Postby briandc » Sun Mar 03, 2013 2:54 pm
tekkentool wrote:Erm, you can run multiple instances of kinda anything software wise :?
Thousands? Got an audio demo? :)
Brian
LinuxSynths.com
briandc
Real name: brian
Postby briandc » Sat Mar 09, 2013 10:05 pm
I'd be curious to hear from anyone who uses multiple instances of their softsynths.
-Which synths do you use as multiple?
-Which types of sounds do you use multiple instances to get?
-Do you experience performance issues (RAM, CPU) when using multiple instances?
-Anyone use "only" multiple instances for certain purposes?
brian
LinuxSynths.com
briandc
Real name: brian
Postby CS_TBL » Sun Mar 10, 2013 12:48 am
briandc wrote:I'd be curious to hear from anyone who uses multiple instances of their softsynths.
Well, here ya go!
Others: don't bother clicking, "you know".. :)
FM8 vids
CS_TBL
Gear: All "In-The-Box"
Mainly FM8
Postby Ashe37 » Sun Mar 10, 2013 1:26 am
brian
which synths as multiple:
Most of them
Which types of sounds:
Many
Performance Issues:
Not since i got a Core2 Quad.
only multiple instance:
Well, if they are making different sounds, sure...
This piece uses multiple instances of Synth1 and KX-16:
Real name: Unpronounceable
Band: Eridani V
Postby briandc » Mon Mar 11, 2013 10:59 am
CS_TBL wrote:
Well, here ya go!
Yes, thank you! I actually saw your page before you responded here. I see that you run multiple instances of FM8, and some of the sounds are quite interesting and rich!
It seems clear to me that (one of ) the advantanges of having a softsynth is precisely in this, that you can run multiple instances and obtain much wideness and complexity. Something I don't think you can find anywhere in a hardware synth.
Does FM8 have some type of setting that will remember all the instances and open them simultaneously, or do you have to open them one-by-one? (I suppose doing it one-by-one would discourage people from exploring this capability..)
brian
LinuxSynths.com
briandc
Real name: brian
Postby briandc » Mon Mar 11, 2013 11:07 am
Most of them
Many
Performance Issues:
Hi Ashe37,
interesting piece! The lead patch has kind of a haunting timbre. Was it multiples of the same patch or different ones put togther?
I've played around with Synth1 a bit in the past.. but this is the first one I've heard using multiple instances. Thanks!
brian
LinuxSynths.com
briandc
Real name: brian
Postby Ashe37 » Mon Mar 11, 2013 11:18 am
the lead patch was multiple instances of synth1 (or maybe it was KX-16, I'd have to look at the project to see which is which) detuned even so slightly against one another using REAPER's pitch shifter to thicken up the sound. IIRC, the copies were detuned by =/- 1 cent. May have been less.
Band: Eridani V
Postby briandc » Thu Jul 18, 2013 8:19 am
I guess the question is: with the capability if running multiple instances, thereby exponentially increasing the creative power of the softsynth, how is it that hardware synths can compete?? Any hardware synth can't ever have all the oscillators, filters, effects, etc that a softsynth can offer..
brian
LinuxSynths.com
briandc
Real name: brian
Postby Stab Frenzy » Thu Jul 18, 2013 9:03 am
briandc wrote:I guess the question is: with the capability if running multiple instances, thereby exponentially increasing the creative power of the softsynth, how is it that hardware synths can compete?? Any hardware synth can't ever have all the oscillators, filters, effects, etc that a softsynth can offer..
brian
Easy, by multitracking. Make a patch, record the audio, make another patch, record the audio on another track, etc. if you want to be able to tweak the sounds later then save the midi notes and the patch.
Postby Ashe37 » Thu Jul 18, 2013 9:07 am
Hardware synths are increasing their capabilities as well. The Viorus Ti 2 does not have the same limitations as the Virus Ti does not have the same limitations as the Virus C does not have the same limitations as the Virus B does not have the same limitations as the Virus A, for example. They aren't exactly resting on their laurels.
Band: Eridani V
Postby briandc » Thu Jul 18, 2013 5:03 pm
brian
Yes; well that is true for using multiple tracks. But you can't just double the oscillators on a hardware synth. If it has 4 oscillators, that's all. Whereas a virtual synth in multiple instance allows recording a whole slew of oscillators, filters, whatever, all at the same time.
This seems to have an infinite power potential, particularly in live performance.
brian
LinuxSynths.com
briandc
Real name: brian
Next
