MIDI for iPad Mini with Lightning Connector
thinkingbeat
Gear: Korg Polysix, Waldorf Micro Q, Roland JP-8000, Korg Prophecy, Waldorf Nave
Post by thinkingbeat » Thu Jul 04, 2013 8:31 pm
I need a little help here as I'm new to iPad synths -
Trying to connect a MIDI keyboard (Axiom 25) to an iPad Mini to play the Waldorf Nave (amazing synth) but a bunch of the Core MIDI-compliant products use the old 30-pin connector and don't interface with the new Lightning connection.
Just scored an iRig Midi on eBay, but when I look at the Apple Lightning to 30-Pin Adapter a lot of the sellers warn it does not work for audio. Is that a warning to MIDI noobs who think MIDI acts like an Audio-Out, or does it really mean the Apple adapter will not work for transmitting MIDI notes from the keyboard? What do you do if the latter is true?
Finally - any rec's for an Audio-Out solution for the iPad Mini so I can plug it into my mixer?
Thanks in advance!
Blue Monster 65
Re: MIDI for iPad Mini with Lightning Connector
Post by Blue Monster 65 » Fri Jul 05, 2013 2:43 am
I use the camera connector for my midi hookup (with a Samson Graphite 25) and then the audio out into my mixer. Works for me!
I have an iPad Mini and it also powers the Samson.
Muhahahahahahahahaha!
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Fri Jul 05, 2013 3:37 am
MIDI isn't audio, it's just note on/off info, what note, instrument data, and various modulations. Pretty much a constant stream of letters and numbers as you play. Audio comes out of the iPad anyway, just hook the headphones out to a channel on your mixer. Works perfectly with my ipad4 , and I get no audio signal loss Iike you'd imagine when using a headphones output. Maybe my mixer amplifies it, I don't know. I just have a cheap Phonic 11channel mixer, no expensive desk.
thinkingbeat
Post by thinkingbeat » Fri Jul 05, 2013 3:54 am
Blue Monster 65 wrote:I use the camera connector for my midi hookup (with a Samson Graphite 25) and then the audio out into my mixer. Works for me!
What camera connector? And is the audio out from the Samson or the iPad's phone jack?
thinkingbeat
Post by thinkingbeat » Fri Jul 05, 2013 3:57 am
Bitexion wrote:MIDI isn't audio, it's just note on/off info, what note, instrument data, and various modulations. Pretty much a constant stream of letters and numbers as you play. Audio comes out of the iPad anyway, just hook the headphones out to a channel on your mixer. Works perfectly with my ipad4 , and I get no audio signal loss Iike you'd imagine when using a headphones output. Maybe my mixer amplifies it, I don't know. I just have a cheap Phonic 11channel mixer, no expensive desk.
Thanks. I knew that, but the warning about no audio support made me wonder if MIDI was not supported on the Apple adapter for some odd reason.
Thanks also on the audio out via the phone jack. The sound quality is pretty good on these things, and jaw-dropping with Nave! 8-)
Bitexion
Roland D-50
Creamware Minimax
Yamaha DX7s
Post by Bitexion » Fri Jul 05, 2013 4:08 am
the no audio support warning is likely for old dock units that play audio through the connector, like speakers that don't use Bluetooth for instance. There is a cable meant to connect a camera to the iPad to send over pictures etc, that is commonly used as MIDI cable. I might be easier available than a specific MIDI cable. But you already have the MIDI hookup it seems :)
haj
Post by haj » Fri Jul 05, 2013 12:00 pm
Alesis IO dock is reported to be working with ipad4 so maybe it's basically supported?
I don't actually have an IO dock so I'm not sure, but it's taking audio without headphone amp right? I wonder how different the audio with or without thru the headphone amp.
Blue Monster 65
Post by Blue Monster 65 » Fri Jul 05, 2013 1:20 pm
Right - audio out is the phones out on the iPad itself. I use a 1/8" stereo to two 1/4" splitter cable into my mixer (a Mackie 820i). It works good enough for me.
The camera connection I use is this: http://store.apple.com/us/product/MD821 ... ra-adapter If you already have a MIDI connection, you don't need this.
Roland makes an audio/MIDI interface that is for use with the iPad: it uses your connector cable (charger cable) to plug into a USB port on the back and then allows for both MIDI and audio to pass through the unit. I have not tested this so I can't say it works. http://www.sweetwater.com/store/detail/DuoCaptureEX/ I would imagine there are others, too.
thinkingbeat
Post by thinkingbeat » Fri Jul 05, 2013 4:06 pm
Blue Monster 65 wrote:Right - audio out is the phones out on the iPad itself. I use a 1/8" stereo to two 1/4" splitter cable into my mixer (a Mackie 820i). It works good enough for me.
All helpful, thanks. I'm going to just grab a Lightning to 30-pin then, since I'm getting the iRig and that should suffice. If I want more than one MIDI input, would a MIDI patchbay work on the iPad?
If I needed to make a Lightning to 30-pin connection from scratch, I would definitely use the Apple camera connector (Lightning to USB). That Roland Duo looks perfect though, having the audio as well.
