Newbie question about MIDI/audio card
Postby moog-lover » Sat Mar 22, 2014 11:35 pm
This is basic, but now I'm wondering something.
1 -> Let's say I have an audio card without MIDI inputs but it is connected to my PC, with its ASIO drivers installed.
Now I connect a MIDI keyboard with USB port into my PC.
Both are connected to the PC, and in my sequencer I use my audio card and my MIDI keyboard with VSTs. Does that configuration have the same latency as if I connect a MIDI keyboard into an audio card which HAS got MIDI inputs?
2 -> Let's say I have a synth with MIDI input, and again, an audio card without MIDI input. Then I connect the synth with the PC using a MIDI-to-USB cable. Can I play the synth with my MIDI keyboard, also connected to the PC? Is the same latency as if I connect the synth directly with the MIDI keyboard?
moog-lover
Re: Newbie question about MIDI/audio card
Postby meatballfulton » Sat Mar 22, 2014 11:58 pm
The answer to both questions is YES, latency should be the same.
Postby moog-lover » Sun Mar 23, 2014 12:04 am
Thanks!
By the way, my MIDI keyboard is M-audio Oxygen 49. It doesn't have the conventional MIDI output. It uses something similar to the printer's USB connectors. In order to your answer I can play through my PC, that's great. But: Am I still able to find some adapter to connect it to a synth with conventional MIDI input? (Just to avoid having a computer)
moog-lover
Postby Stab Frenzy » Sun Mar 23, 2014 1:01 am
No, although there are some small boxes that will act as a midi host now and do a similar thing. It's still using a computer, but it's a tiny computer in a box with no screen so almost like not using one at all. Check out the Kenton USB midi host and the iconnectmidi.
Postby gmeredith » Sun Mar 23, 2014 3:18 am
Yep, Kenton MIDI host box is what you need, I'm getting one:
http://www.kentonuk.com/products/items/ ... host.shtml
Enables USB only keyboards to connect to MIDI equipment, standalone, no computer needed, DC power supply included. Also provides power for the USB keyboard.
Stab: Your "computer in a box" wouldn't happen to be a v-machine, would it?
Cheers, Graham
gmeredith
Band: Warning Will Robinson
Postby Ashe37 » Sun Mar 23, 2014 3:20 am
gmeredith, Kenton's device is a computer in a box.
Real name: Unpronounceable
Band: Eridani V
Postby gmeredith » Sun Mar 23, 2014 3:25 am
Ah, that's what stab was meaning. Cheers,
gmeredith
Postby moog-lover » Sun Mar 23, 2014 7:11 pm
Oh I see. Thanks for letting me know. It is rather expensive to me just for my unique purpose, but it looks like it deserves it.
I made a mistake by buying the Oxygen49. I was conformed enough with its sliders and knobs, that response in real-time, whereas others show a little bit of stepping when moving them fast.
I didn't think about the midi input. I wonder why m-audio didn't include it, it shouldn't be so hard to include it. It must be conceptual.
Well..
Cheers
moog-lover
Postby Ashe37 » Mon Mar 24, 2014 1:26 am
Older Oxygens have a midi port... We have an Oxygen 25 that we use all the time for testing synths, noodling around etc.
Band: Eridani V
Postby seamonkey » Tue Mar 25, 2014 6:22 pm
moog-lover wrote:I didn't think about the midi input. I wonder why m-audio didn't include it, it shouldn't be so hard to include it. It must be conceptual.
Well..
Cheers
cutting cost of production?
seamonkey
Real name: Rick
