SQ8l Aftertouch question
mharris80
Gear: Korg M1
MicroKorg
Ensoniq ASR 88
Ensoniq ESQ-1
Roland JX-8P
Roland MKS-50
Yamaha RX7
M Audio Oxygen 49
AV Linux
Post by mharris80 » Fri Nov 21, 2014 4:16 pm
Does anyone know which modulator in SQ8l corresponds with polyphonic aftertouch? According to the readme, it should work, but I don't see key presssure anywhere in the mod list. Thanks
Real name: Unpronounceable
Band: Eridani V
Re: SQ8l Aftertouch question
Post by Ashe37 » Sat Nov 22, 2014 12:23 am
I'm reasonably sure it is listed as 'PRESS' If you double click the mod source it is like the 13th item listed. (Channel Pressure is CHPRESS which on my display shows up in the last column)
mharris80
Gear: Korg M1
MicroKorg
Ensoniq ASR 88
Ensoniq ESQ-1
Roland JX-8P
Roland MKS-50
Yamaha RX7
M Audio Oxygen 49
AV Linux
Post by mharris80 » Sat Nov 22, 2014 2:41 pm
Thanks, that's kinda what I figured. Which means the sequencer program I'm using doesn't output poly AT, though there's a MIDI automation listed as "Key Press". :x
Band: Eridani V
Post by Ashe37 » Sat Nov 22, 2014 8:33 pm
dunno if that's channel or poly AT...
mharris80
Gear: Korg M1
MicroKorg
Ensoniq ASR 88
Ensoniq ESQ-1
Roland JX-8P
Roland MKS-50
Yamaha RX7
M Audio Oxygen 49
AV Linux
Post by mharris80 » Sat Nov 22, 2014 9:04 pm
Ashe37 wrote:dunno if that's channel or poly AT...
There are seperate options for "Key Press" and "Channel Press", which is what led me to believe that key=poly AT. Was also able to get regular channel AT by using the channel press option.
Band: Eridani V
Post by Ashe37 » Sat Nov 22, 2014 9:18 pm
yep that would be it, then
