SQ8l Aftertouch question
Posted: Fri Nov 21, 2014 4:16 pm
by mharris80
Does anyone know which modulator in SQ8l corresponds with polyphonic aftertouch? According to the readme, it should work, but I don't see key presssure anywhere in the mod list. Thanks
Re: SQ8l Aftertouch question
Posted: Sat Nov 22, 2014 12:23 am
by Ashe37
I'm reasonably sure it is listed as 'PRESS' If you double click the mod source it is like the 13th item listed. (Channel Pressure is CHPRESS which on my display shows up in the last column)
Posted: Sat Nov 22, 2014 2:41 pm
by mharris80
Thanks, that's kinda what I figured. Which means the sequencer program I'm using doesn't output poly AT, though there's a MIDI automation listed as "Key Press". :x
Posted: Sat Nov 22, 2014 8:33 pm
by Ashe37
dunno if that's channel or poly AT...
Posted: Sat Nov 22, 2014 9:04 pm
by mharris80
Ashe37 wrote:dunno if that's channel or poly AT...
There are seperate options for "Key Press" and "Channel Press", which is what led me to believe that key=poly AT. Was also able to get regular channel AT by using the channel press option.
Posted: Sat Nov 22, 2014 9:18 pm
by Ashe37
yep that would be it, then
