Custom-built multi-bank Roland M-256/M-512 memory cards
dojoe
Re: Custom-built multi-bank Roland M-256/M-512 memory cards
Post by dojoe » Tue Jan 14, 2020 4:54 pm
Hah, yeah, the 16A won't do you much good :) The D-50 uses 256kbit, i.e. 32kbyte, so that's A0 thru A14. Our card uses a 4mbit chip and supplies A15 thru A18 from the slide switches. Note that ordering the address bits in this way is not really necessary - you can freely rearrange address bits as you please if it simplifies PCB routing. The MRAM isn't going to care where those bytes are stored after all :)
The edge connector actually supports up to 19 address bits (the MR signal is used for A18 on some PCM ROM cards) and I've built jumpers onto the card that will switch A15 thru A18 between the slide switches and the edge connector, allowing any configuration between 16 banks of 256kbit and one bank of 4mbit. We only ship the 16x256 and 8x512 variants since that's the only RAM card sizes used by synths, but I have deliberately made the card hackable that way if anyone wants to dabble in custom PCM cards ;)
Avro_Arrow
Real name: James
Gear: Korg M1
Roland D-50
Yamaha DX21
Roland Fantom XR
Novation Impulse 49
Focusrite Scarlet 2i4
Post by Avro_Arrow » Thu Jan 16, 2020 1:21 am
Thank you dojoe for all your help and insight.
I'm going to go with a static ram with battery and MXD1210 (or similar).
I'm just going to use dip switches for the extra address lines.
This way I can just stick with the 5 volt logic and not have to
convert to 3v3 data lines. I'm a wimp, I know. Its also dirt cheap.
I can live with changing the battery every five years.
Thanks again!
James
dojoe
Post by dojoe » Thu Jan 16, 2020 10:50 pm
I'm a wimp, I know.
But you also opt out of a buttload of headaches ;)
Good luck with your project, let us know how it goes!
Avro_Arrow
Real name: James
Gear: Korg M1
Roland D-50
Yamaha DX21
Roland Fantom XR
Novation Impulse 49
Post by Avro_Arrow » Fri Jan 17, 2020 1:20 am
I'm a wimp, I know.
Thanks, I will!
ʝɵʝɵ
Gear: Roland D-50, U-220, XV-5080, Yamaha AN1x, CS1x, CS6R, TG77, Korg X5DR, Kawai K4, Kurzweil K2500
Post by ʝɵʝɵ » Tue Jan 28, 2020 10:57 pm
We are out of stock!
It took a bit longer this time due to the registration form mishap, but the last cards are now finally sold. However, there might be another batch coming (definitely not before the second half of 2020, maybe even later), so you can sign up at https://sagamusix.de/other/roland_memory_cards/ to be notified when the next batch is ready. (this time the registration form will hopefully not break after a month ;))
glengood87
Post by glengood87 » Fri Apr 24, 2020 1:42 am
Hi all,
I have sold all my Roland synths and so no longer need my card - please PM if anyone is looking for one. I am based in Adelaide Australia, but can post worldwide.
ʝɵʝɵ
Post by ʝɵʝɵ » Fri Apr 24, 2020 6:27 pm
On Gearslutz someone was recently asking for one:
https://www.gearslutz.com/board/showpos ... stcount=14
Also here but a few months ago:
https://www.gearslutz.com/board/showpos ... tcount=321
RDP
Post by RDP » Sun Jul 05, 2020 9:42 am
I am also looking for one. glengood87 cannot be PM'ed so I guess I am looking for any leads before signing up for the main list.
thanks,
RDP
ʝɵʝɵ
Post by ʝɵʝɵ » Sun Jul 05, 2020 12:08 pm
Signing up to our list doesn't mean that you commit to any purchase; you will simply be notified when the cards will be available. So there is nothing wrong with signing up and still looking for someone else selling their card at the same time.
rd3d2
Post by rd3d2 » Thu Jul 16, 2020 2:05 pm
Just found your site = what an amazing project! Such a shame that you have no stock though.
Are you aware of anywhere else doing this (seems like a dead cert for someone in Shenzhen?!)
ʝɵʝɵ
Post by ʝɵʝɵ » Thu Jul 16, 2020 2:29 pm
Yes, there are definitely other people exploring this space, but so far noone else is making M256/M512 replacements. There are some Yamaha card remakes that were already linked in this thread, and not too long ago I saw another Roland memory card remake (also based on MRAM) that was sold commercially via Thomann. However, I cannot find it in the Thomann store anymore, not sure what's going on there. That memory card was considerably more expensive than ours, but also offered more memory banks.
Edit: This is the one, it's a Roland M-16C / M-64C replacement: https://shop.waverex.de/en/mc-256-memor ... vices.html
Post by madtheory » Sun Jul 19, 2020 1:19 pm
Wow very expensive but it does come in a very nice box with cool switches, which straight off prevents it from working on Akai devices.
ʝɵʝɵ
Post by ʝɵʝɵ » Sun Jul 19, 2020 4:14 pm
So Akai also used the M16C/M64C format in their synths?
Post by madtheory » Mon Jul 20, 2020 12:00 am
Oops, I thought it was an M-256 replacement my bad.
ʝɵʝɵ
Post by ʝɵʝɵ » Wed Jul 22, 2020 8:24 am
And to be fair:
- Their cartridge must be containing a much bigger MRAM chip, holding 256 banks (assuming M64C is 8KB, that would be a 2MB MRAM chip compared to our 512KB). The MRAM chip is the single most expensive component in our design, so it must be a big factor in their pricing as well.
- The margins on our memory card are minimal. If we wanted to run a company like WaveReX with our cards in a profitable way, they would have to be priced well above 100 Euros as well, I'm sure.
