D-50 Plastic Key Guard
Moog_Meister
Post by Moog_Meister » Wed Jun 28, 2017 6:12 am
Bit of an odd question here, and I don't expect a solution but I thought I'd ask anyway. :D Does anyone know where or how to get a hold of the little plastic key guards that went in D-50s and other Rolands of that era? The ones that are glued under the keys. I had my D-50 cleaned and serviced by a local tech a couple of years ago, unbeknownst to me he threw away the plastic guards when he cleaned the contacts, I only discovered this after I recently took it apart to replace a broken key. I know it's not that big of a deal and not having them doesn't effect the keyboard at all, but I am a completist and it is driving me nuts. Well, I think I just won the most random question of the week award on this forum! :D
synthRodriguez
Real name: Scott
Gear: Moog - Roland - Yamaha
Re: D-50 Plastic Key Guard
Post by synthRodriguez » Thu Jul 27, 2017 12:29 am
They aren't plastic, more of a thin-pressed translucent felt. Well, I suppose the material probably is a plastic filament of some sort, but it's more like a thin liner material for clothing or drapes.
When I reworked my D-50 several years back I got replacements from Rob Senso at Vintage Planet but he shut that down of course. They'd be a time-consuming b!tch to make by hand as they're wide-slit and different widths, but it could be done if you were determined enough.
If you'd like I could send you the old Coke-stained set from mine as a pattern (I never throw anything away!) or you could try washing and bleaching them for reuse.
Have you tried Roland parts department for grins? They never have anything though... :roll:
Moog_Meister
Post by Moog_Meister » Thu Jul 27, 2017 7:07 pm
synthRodriguez wrote:They aren't plastic, more of a thin-pressed translucent felt. Well, I suppose the material probably is a plastic filament of some sort, but it's more like a thin liner material for clothing or drapes.
Hi there! Thanks for the reply, I have contacted Roland Parts after your recommendation; however I don't anticipate they will be able to help me. I will keep you posted if they don't turn up with anything I will gladly take the old coke-stained ones off your hands! :D Thank You!
