Juno 6 Bender issue
wjames
Juno 6 Bender issue
Post by wjames » Sat Mar 03, 2018 11:30 pm
I picked up a used Juno 6 and am trying to run test/calibration. When increasing the DCO bender sense slider,from 0-10, the note played changes pitch with out moving the bender. Is this normal? I don't believe it is.
I am trying to trouble shoot the problem . I downloaded the manuals but there is no diagram for the bender board. Can I get a copy of this diagram? Any help with what could be causing this would be appreciated.
Thanks
AK79
Gear: RolandSH09, RolandSH2, Korg PS6, Korg700S, SolinaStringEnsemble, MFOS SoundLabUltimate, YamahaDX7, YamahaCS01,SielOpera6, Korg Mono/Poly,OberheimOB8
Re: Juno 6 Bender issue
Post by AK79 » Wed Apr 18, 2018 10:44 am
Bender alignement is off.
there is a potentiometer on which the bender-lever is mounted. You unscrew the lever slightly from the shaft of the pot and then turn the pot until the pitch does not vary with the DCO Fader.
Make sure the tuning pot on the back of the synth is centered.
V301H
Band: The Characters
Post by V301H » Sun Apr 22, 2018 8:25 am
Have the same problem with my Juno 60. Good to know it's a simple fix. Thanks AK.
