Juno 6 Bender issue
Juno 6 Bender issue
Postby wjames » Sat Mar 03, 2018 11:30 pm
I picked up a used Juno 6 and am trying to run test/calibration. When increasing the DCO bender sense slider,from 0-10, the note played changes pitch with out moving the bender. Is this normal? I don't believe it is.
I am trying to trouble shoot the problem . I downloaded the manuals but there is no diagram for the bender board. Can I get a copy of this diagram? Any help with what could be causing this would be appreciated.
Thanks
wjames
Re: Juno 6 Bender issue
Postby AK79 » Wed Apr 18, 2018 10:44 am
Bender alignement is off.
there is a potentiometer on which the bender-lever is mounted. You unscrew the lever slightly from the shaft of the pot and then turn the pot until the pitch does not vary with the DCO Fader.
Make sure the tuning pot on the back of the synth is centered.
AK79
Gear: RolandSH09, RolandSH2, Korg PS6, Korg700S, SolinaStringEnsemble, MFOS SoundLabUltimate, YamahaDX7, YamahaCS01,SielOpera6, Korg Mono/Poly,OberheimOB8
Postby V301H » Sun Apr 22, 2018 8:25 am
Have the same problem with my Juno 60. Good to know it's a simple fix. Thanks AK.
Prophet 5 rev.2, Pro-One, Juno 60, Jupiter 6, Matrix 12, OB8, MS20, Poly 800, CS70M, DX-7, CP35, Casio PX-5S, Hammond C3/M102, Vox Continental/Super Continental, Gibson G101, Farfisa Compact, RMI 300A, Pianet N, Combo Pianet, S770, S760, S50
V301H
Band: The Characters
