The front long bar and side panels are milled from Sapele wood.
The wood is finished in Danish oil. It brings out all the subtle wood grain effect.
The MDF base is covered with oil as well.
Panel hinges pins are installed.
Aluminum foil shielding cut to original dimensions.
Knockin inserts for all screws have been installed
The bottom side of the case has been painted flat black. The same as the original case.
https://www.ebay.co.uk/itm/162944202961
