Korg Polysix Wood Case Analog Synthesizer.African Sapele and Oak wood
London, United Kingdom
2 PolySix wood cases. Auction
https://www.ebay.co.uk/itm/162956263213
https://www.ebay.co.uk/itm/162956276376
The front long bars and side panels are milled from African Sapele and Oak.
The wood is finished in Danish oil. It brings out all the subtle wood grain effect.
The MDF base is covered with oil as well.
Panel hinges pins are installed.
Aluminum foil shielding cut to original dimensions.
Knock in inserts for all screws has been installed
The bottom side of the case has been painted flat black. The same as the original case.
