Linn drum Lm2 patterns not playing
Postby apos » Thu May 17, 2018 4:47 pm
Hi from a newbie
I have a Linn drum lm2 that has a problem.All the knobs, sliders and buttons work flawless after a good cleaning that I have made.
The main problem I have right now is that when I press start/stop button does nothing. Not playing anything. Only a beep when I press it. It stays red when I press it and cannot hear anything from the instrument .
I try also to factory reset it by holding load and erase together but nothing.
I also cleaned and replace battery on the power supply left bottom corner.
If someone knows something that could help me I would appreciate.
Best regards
Apos
apos
Re: Linn drum Lm2 patterns not playing
Postby Z » Thu May 17, 2018 6:29 pm
Dead battery.
Have you cleared the pattern then try recording a new one?
Z
Postby apos » Thu May 17, 2018 9:13 pm
I have already changed the battery,i will try to record a pattern.
Thanks.
apos
Postby apos » Fri May 18, 2018 9:55 am
I did erase a pattern and I heard a beep sound.Then I press record and play ,start button stays red but no metronome or pattern rolling.
apos
Return to Gear Services & Other Goods
