Polivoks filter pedal
FlavioB
Post by FlavioB » Mon Dec 23, 2019 11:14 am
Hi all.
I'm looking for someone who owns an original Polivoks filter pedal and could share pictures of it. I have got one, but it came without screws, so now I don't know if I need one long screw or many short screws in the inside.
Also, schematics would be very appreciated as well!
Thanks in advance for any help!
Flavio.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Circuit bent Hing-Hon
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Re: Polivoks filter pedal
Post by Polivoks » Sat Jan 11, 2020 5:49 pm
Hi there, I’m new. There is one of those pedals entities to me. When it arrives I can do a few pics for you if it
LTJ Soundcrafts.
FlavioB
Post by FlavioB » Sun Jan 12, 2020 6:26 pm
Oh yes, please! Thank you in advance!
F.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Post by Polivoks » Sun Jan 12, 2020 7:18 pm
Yes we will do alien autopsy on it. I need to use a pedal because the formanta pot is going to be arthritic from all of my cutoff knob twirling.
LTJ Soundcrafts.
FlavioB
Post by FlavioB » Sun Jan 12, 2020 10:58 pm
Hahaha! :-) I can imagine! ;-)
F.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Post by Polivoks » Thu Jan 16, 2020 2:59 am
Ok here are the pics, the pedal came in today, so I took it apart to document its innards...
LTJ Soundcrafts.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Post by Polivoks » Thu Jan 16, 2020 3:01 am
LTJ Soundcrafts.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Post by Polivoks » Thu Jan 16, 2020 3:02 am
LTJ Soundcrafts.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Post by Polivoks » Thu Jan 16, 2020 3:03 am
The pot is operated by a string/spring mechanism. Which is neat
LTJ Soundcrafts.
FlavioB
Post by FlavioB » Thu Jan 16, 2020 6:44 am
Thanks for the pics. Can you also show me how the screws hold it all together internally? I mean the big screws, which keep the case together...
My pedal is the earlier, first version: it has optical interface...
F.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Post by Polivoks » Thu Jan 16, 2020 6:47 am
Pot reads 1.2k relaxed to 2.78k when the pedal is depressed. Only the middle three pins are used in the DIN cable
LTJ Soundcrafts.
FlavioB
Post by FlavioB » Thu Jan 16, 2020 1:23 pm
errr... OK, but this is not what I requested earlier :-)
I would like to have the pictures of the big screws holding the pedal parts together...
F.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Post by Polivoks » Thu Jan 16, 2020 5:56 pm
Sure thing, I didn’t know about an optical one! That’s cool
LTJ Soundcrafts.
FlavioB
Post by FlavioB » Thu Jan 16, 2020 10:12 pm
Thanks in advance for your pics of the interior and the screws.
Mine looks like this. Also: is it supposed to stay in position, when pressed/depressed? Or should it always go back down?
F.
Polivoks
Gear: Polivoks 1987
DX7 FD ll 1987
Casio SK-1
Novation Impulse 49
Acid Pro 9
Band: AFTER[MATH]
Post by Polivoks » Thu Jan 16, 2020 11:51 pm
I see what you mean, the big bolts holding the pedal to the base. The entire layout is different between these two pedals unfortunately. Mine has a big spring that returns the pedal to flat when you step off of it. It looks like your pedal should have a machined shaft running through the whole thing including that bellcrank in the middle. I’m sorry I can’t be of more help, hopefully someone has the optical kind to look at.
LTJ Soundcrafts.
