VIRTUAL EDITOR / PROGRAMMER FOR OBERHEIM OB-Xa - (ENCORE 1.2
Postby JamesBRey » Thu Aug 07, 2014 5:19 pm
VIRTUAL EDITOR / PROGRAMMER FOR OBERHEIM OB-Xa - (ENCORE 1.2) - LOGIC
**** NEW PRODUCT **** !! :D :D :D :D :D :lol:
This software is a Virtual synthesizer programmer for use with the Oberheim OB-Xa synthesizer.**** It emulates the OB-Xa front panel in a software environment within the APPLE LOGIC audio/sequencer program (formerly Emagic Logic).**** To use this software you MUST have a valid copy of LOGIC on your computer (see below), an ENCORE ELECTRONICS MIDI upgraded OB-Xa running firmware v1.2 or higher,* and a MIDI interface which connects your computer via MIDI cable to your Oberheim synthesizer.***** This software CANNOT be used as a stand alone application under any circumstances.* *
Upon purchase, you will receive a ZIP archive of the editor you purchased for Logic.**** UNZIP this archive and you will have a LOGIC song document you can now open in the Logic program.***** Once open, you will see the editor on your screen and you can then discover the pleasures of a Virtual ACCESS programmer for your Oberheim OB-Xa synthesizer!
NOTE!! ** This software requires an ENCORE ELECTRONICS upgraded OB-Xa in the form of both a hardware kit for your synth and the correct software version running on it (v1.2 or higher) - which can be easily installed by user via FLASH upgrade over MIDI.
OVERVIEW:
This editor is physically laid out to emulate the Oberheim OB-Xa front panel. ** If you're familiar with the OB-Xa layout then you should feel right at home here.**** I've adopted certain additions including text feedback, a RESET function, ALL NOTES OFF, and a few other performance tools.***
All programmable functions of the OB-Xa front panel are represented here - and this does not include the HOLD and CHORD buttons (please see the included photo to understand the layout).*** None of the live Modulation bend assembly panel is accessible with MIDI commands either - but everything else programmable is in there including SPLIT, DOUBLE and SINGLE modes.**** Editing is possible on both sides of the SPLIT or on both halves of a DOUBLE using the UPPER and LOWER function to select the live area.
All real time moves are recordable by the Logic sequencer for repeatable real time changes on playback.***** Or as an option you can automate these parameters with LOGIC'S hyperdraw function.*** You may also remotely control these SYSEX faders and buttons via a hardware control surface if you take the time to tailor the controls to suit your individual hardware.**** This is not difficult to do and needs only be done once and then saved for future sessions.
This programmer resides in one layer of the LOGIC environment hierarchy - and is importable to your personal AUTOLOAD song (notes on how to do so are also included).*** It is not a plug-in, but a page in the environment which can be imported into your song documents or run alongside your current work simultaneously as a second song.
Detailed documents are included with your purchase and cover all aspects of usage - both remedial and advanced.
SYSTEM REQUIREMENTS:
This editor is brand new but is still compatible with many different versions of Logic starting with Emagic MAC Version 3.x.**** It is compatible with ALL versions of Logic through v9.**** It is also compatible with Logic Express v7 - 9.**** If you have a version 8 Logic you must use v 8.01 or higher which fixes a SYSEX bug that renders v8.0 inoperable.***** Logic X versions will be available summer 2014 with free upgrade path if you purchase now.
This editor is also compatible with the v4 - v6 PC versions of Logic (please specify upon purchase).***** In all v5's - it is compatible down to Logic SILVER.**** NOT compatible with Micro-Logic or any of the other earlier neutered Emagic bundled versions.
This editor is designed to fit on one screen with a screen resolution of 1024 X 768 or larger but will also work on smaller screens.
TERMS and CONDITIONS:
Free Delivery is included with purchase.**** Free delivery includes all destinations worldwide.**** Due to the unpredictable nature of international mail and semi-monthly only mailings - please allow 4-6 weeks for delivery from the date of purchase.***** If you prefer expedited delivery please contact me here for other delivery options.
I only accept*PAYPAL.*** Because this is a software only item, there are no returns allowed.*** Please contact me via the EBAY messaging system with any questions before the purchase.
I also offer a customizing service for your software to help integrate it more deeply into your personal set-up should you require advanced help.*** Please contact me here for more info.
FREE DELIVERY IMMEDIATELY VIA EMAIL FOR NON-EBAY BUYERS!
Kind Regards,
jbrey21@gmail.com
EBAY USER NAME: Virtual-PG
JamesBRey
Return to Gear Services & Other Goods
