Yamaha RX-15 Drum Machine Help!
Hank Linderman
Post by Hank Linderman » Wed Oct 07, 2015 11:34 am
Hi there, first posting. I have a Yamaha RX-15 that has lost it's factory patterns. Is there any way to restore them? Sysex dump, any options? Thanks! Best....H
deeluxdx7
Re: Yamaha RX-15 Drum Machine Help!
Post by deeluxdx7 » Fri Jul 29, 2016 12:57 am
From my experience using RX drum machines my comment is that none of those patterns are anything you can't program yourself,
If that doesn't work for you. google drum midi files, download a bunch of beats, dump them into your DAW, change the midi notes on the sequencer or the Yammy to match and then just record as many new beats as you can, I guarantee if you use some of the MIDI patterns from BFD, Logic ANYTHING they will be much better than the ones in the RX15
Good opportunity to get your programming chops up to speed
