If you guys can help with needing a Keyboard contact strip for Roland synthesizer, the green plastic printed circuit strip hidden underneath the keys on the keybed. I tried to remove the glue with a razor blade and ended up cutting away some of the circuit print. DOh!
Apparently the U20 or DJ70 is also compatible. Actually if you have the Keybed Id be willing to consider that as a purchase option as well.
Thanks!!
