Emu-Emulator I samples
ESTD
Post by ESTD » Fri Sep 15, 2017 8:53 am
Hi, guys! Im looking for a choir and voice samples Emu-Emulator I used JMJ in Ethnicolor. Where i can find this?
Maybe somebody can share this choir and voice samples for me in any formats?
Re: Emu-Emulator I samples
Post by madtheory » Fri Sep 15, 2017 9:01 am
It's in UVI Emulation One.
crystalmsc
Band: Crystaline
Post by crystalmsc » Mon Sep 18, 2017 6:58 am
While listening to the E4 library demos, I've heard an almost similar choir. It's not an 8bit samples though and might not be exactly what you are looking for, but maybe worth to listen especially since it's only $19.95 with lots of E-mu's signature sounds. You might also want to check the E-max library which has some vocals as well.
Kaossilatron - Voicillator
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Mon Sep 18, 2017 7:43 am
Which are all the same recordings, more than likely.
Post by madtheory » Mon Sep 18, 2017 1:00 pm
E4 library was mostly new recordings, very little from any of the EI sessions, mainly because the tapes were lost by then :( . Has a small number of things taken off EI library, possibly sampled back off an original machine I don't know. But all of the orchestral stuff was redone, with some new choirs IIRC.
EII library was made from the same recording sessions as the EI library, sampled again into the new machine, so they will sound somewhat similar however big caveat is that a lot of talented users also contributed to the factory library over time, so you'll find that a lot of the classics were originated that way.
EIIIx library has very little of the EI and a good bit of EII session material, but now in stereo and transferred digitally. The giveaway for those ones is the strange sampling rate of the Sony PCM 1630 used for capture- 44.05kHz. A lot of the "World" library was done that way, for example the wonderful dulcimer (which arguably sounds better in the compressed Proteus version, than in the full range EIIIx library version). Another big caveat- the EI colours the sound quite a bit, so the character of especially vocal sounds can by quite different than on the later Emulators.
I have all of the above libraries and IMO the only way to get the exact sound you want is with the UVI. Unless you can find an EI owner who (a) has all of the original libraries, and (b) is willing to share them!
