Clipping and distortion when using soundfonts
Postby PabstBlueRibbon » Sun Dec 23, 2018 4:47 pm
A while ago I've found some great soundfonts of two harpsichords. The first one contains the sound of a delicate french harpsichord and the other one offers the sound of an Italian harpsichord with a more solid sound. Both contain samples of every key with 4 plectrum settings. (On harpsichords you can set the position of the plectrums plucking the strings to edit the sound from that typical silver harpsichord character to a lute-like sound.)
Also a soundfont of a classical house organ (not electric but with pipes) can be found.
It really sounds good. I thought I've discovered a gem. But I think the gem has to be polished.
I've used the organ soundfont to play a midi-file of Tocatta from Bach. During chords with many tones the sound was distorted. Briefly I was affraid I'm having troubles with my audio interface and I should afford a new one, however there are no other signs my interface is malfunctioning.
I think the samples have to be edited with the EQ, just like you're editing the individual tracks in your mix. Otherwise the tracks together will give you a volume which exceeds the normalisation level and then clipping and distortion will occur.
I have no experience with this. So if you can tell me briefly what I should do and where to look for more information about it you can help me lot! Thanks in advantage
PabstBlueRibbon
Real name: Michael
Gear: Roland RD700sx - SRX04 + SRX10
Roland TB-03
KORG MicroKORG
E-MU ESI 2000 - 128 MB, Turbo Board
Return to Samplers
