Korg ES-1 MIDI LAG
analogaddict
Korg ES-1 MIDI LAG
Post by analogaddict » Mon Mar 25, 2019 5:35 pm
Hi there,
have anyone experienced a midi lag syncing a korg es-1 with another hardware device?
I tried as a master or slave but seems there is a very annoying lag on that machine. If I program a 4/4 snare on each machine it happens that it play off of about 20/30ms. I even tried to load the latest MKII firmware but no luck.
I'm sure it depends on the korg es-1 beacuse i've a bunch of other gear who nicely between each others.
There are very low resource on this topic on the internet.
Jabberwalky
Band: Variar
Re: Korg ES-1 MIDI LAG
Post by Jabberwalky » Tue Mar 26, 2019 11:34 am
I've used it as master and slave tons without ever experiencing a lag. The only time I experienced lag was when syncing to my DAW because it wouldn't start on time. Maybe your samples aren't cropped closely.
analogaddict
Post by analogaddict » Wed Mar 27, 2019 3:16 pm
I loaded the factory samples and synced with an acidlab miami which is analog, either way it lags. It works better if I set it as master but lag very badly when it is slave. If I send midi notes to it lags too.
Do you tried to program just a simple hit 4/4 and see what happen?
If you can test that I really appreciate.
Jabberwalky
Band: Variar
Post by Jabberwalky » Sat Mar 30, 2019 1:23 am
Not sure what you're experiencing, but I have never had any lag issues with the es1. I would suspect it's something else in your chain. Quick clip of the es1 running master clock via midi to a volca fm. You can see it starts and stops, and plays the arp in sync just fine.
