WIDE Open - Akai S612 - Opinions?
translucencecs
Gear: In a transitional phase, so only:
Yamaha SY-22
Roland MC-09
Roland M-VS1
Zoom ST-224
Dubreq Stylophone
Fostex MR8
Post by translucencecs » Sat Mar 10, 2007 6:30 am
Ok - this is pretty broad, as indicated by the title, but I'm interested in people's general feelings about the Akai S612...
Yes, I know it's "crappy" by modern standards, but I'm not really interested in a sampler, per se - I already have an Emu ESI-4000 that I'm MORE than happy with. (Actually, "overjoyed" describes it best!)
What I really want is something kinda different... Just don't ask me what that is - if I knew, I wouldn't be fishing for ideas here!
If I were to get an S612, I'd definitely get one with the QD drive, although that in itself seems to be something of an albatross...
Any thoughts?
Analog Freak
Post by Analog Freak » Sat Mar 10, 2007 7:02 am
Well, they're easy to use, full of character, and really shallow in depth of programming. They are also very limited in terms of sample memory, and there isn't an upgrade path that I am aware of. Saldy, you can't multisample with this machine, which is a really big oversight in my opinion. On the plus side, it sounds like nothing else, and the filters can do insane things to aliasing samples. Another cool feature is the sample start and end sliders. They allow you to change the starting and ending times of the sample on the fly. I don't think the QuickDisk drive is really much of an asset, you can load samples over MIDI almost as quickly, and you don't waste 2U of rackmount space and have to spend ages hunting down more disks if you just transfer samples over MIDI. Overall, if you are willing to put up with its shortcomings it is a worthwhile machine. Just don't expect it to replace your E-Mu.
translucencecs
Yamaha SY-22
Roland MC-09
Roland M-VS1
Zoom ST-224
Dubreq Stylophone
Fostex MR8
Post by translucencecs » Sat Mar 10, 2007 7:23 am
Hmmm. Nope - no illusions about the S612 replacing the ESI-4000!
I mused for a LONG time before settling on the Emu, and I'm entirely satisfied with my choice... What I wanted there was something to give me clean sample reproductions (it's the first time I really used a sampler musically - I don't count my old Electribe S!) with the minimum of personal stress, and it does that very well.
What I want now (additionally) is something TOTALLY different - hence my consideration of a really old lofi sampler with analogue filters!
I'm curious, though - does the S612 do SDS MIDI down/up-loads? Otherwise, would I need any software other than the basic SoundForge that I'm using with the ESI, in order to transfer samples between the PC and an S612?
I'm far more interested in having an alternative "instrument" than a regular "sampler", if that helps anyone..! :)
niemand630
Band: angel eyes
Post by niemand630 » Sat Mar 10, 2007 7:23 am
I love my s612. Actually have two of them although i usually only use one. It was my first sampler and i use it far more than my other ones (s2000 and a4000). I often find that when i try to do something too musical on it i get disappointed, but if i keep things really simple within a couple octaves i get great results. its great for just making a quick sample of some noise and then finding quick loop points and instant drone...
or to just add warmth and low-fi loveliness to samples....although lately ive been contemplating "upgrading" to a prophet 2002. not sure yet.
worth the $50 or so dollars they seem to go for.
Learning the hard way: ax60, s612(2), s900(2), s2000(2),emu: esi32, emax 1 & 2, eiiixp, eiii, drumulator, yamaha tx81z, tambourine. SCI: Prophet 2002, pro1, drumtraks; Roland: msq-700, s760;korg dss1, esq1, tascam 122mk2......
Analog Freak
Post by Analog Freak » Sat Mar 10, 2007 7:33 am
To answer your question, I don't think the Akai uses SDS. I just use some software called S612 Sample Dumper. It is available from this website: http://www.planet-zero.org/wiki/index.php/AkaiS612
piRoN
Gear: A fair bit.
Post by piRoN » Sat Mar 10, 2007 1:28 pm
The Akai S-612, S-700, and X-7000 all use Akai's proprietary sample dump format, they added SDS with the S-900.
Great machines with a lot of character to them.
phloem
Post by phloem » Sat Mar 10, 2007 4:18 pm
They are so cheap for the sound you get that you really can't go wrong. The disk drive isn't necessary, I don't have one.
fdneighbors
Post by fdneighbors » Sat Mar 10, 2007 9:35 pm
I just got mine as my first sampler and I wanted to checkit out with my ax60 synth. It is very LOFI' easy' and versatile for its short sampling time.
I have been making samples with my bass clarinet and running it thru my J-Station and just getting some crazy sounds with it.
Get the Disk drive and some disks with it if you find it. you will want to save the wacky stuff you can make!
Good luck!
Sorcerio
Post by Sorcerio » Sun Mar 11, 2007 4:54 am
piRoN wrote:The Akai S-612, S-700, and X-7000 all use Akai's proprietary sample dump format, they added SDS with the S-900.
It was still proprietary at this point too, I think.
piRoN
Gear: A fair bit.
Post by piRoN » Sun Mar 11, 2007 11:04 am
You mean the S-900? As far as I know it had an early implementation of the SDS standard, but I think it would also perform Akai proprietary sample dumps. Not too sure about that though, I've only used other people's S-900s.
xp50player
Post by xp50player » Sun Mar 11, 2007 12:59 pm
Wow, I wish I would have known about the sample dump thing when I had my S700. It sucked having to load 8 double sided disks for one piano multisample.
Constantine
Gear: ableton live, ESX, kurzweil k2000r, euro/frac/DIY modular, sp-404, and Berna lol
Band: nXLR
Post by Constantine » Sun Mar 11, 2007 4:23 pm
I wonder if there are more 'vintage lo-fi' sounding samplers other than Akai S-xxx , and not something that takes a lot of space and priced tens of thousands dollars when first released :) ..?
translucencecs
Yamaha SY-22
Roland MC-09
Roland M-VS1
Zoom ST-224
Dubreq Stylophone
Fostex MR8
Post by translucencecs » Sun Mar 11, 2007 6:33 pm
Constantine wrote:I wonder if there are more 'vintage lo-fi' sounding samplers other than Akai S-xxx , and not something that takes a lot of space and priced tens of thousands dollars when first released :) ..?
Casio SK-series...
Yamaha VSS-series...
Emu Emax...
Roland S-series...
Or you could just get a Commodore Amiga with MIDI interface - 8-bit, low rate sampling and can take a hard drive!
I'm most interested in the Akai S612 for the combo of lofi sampling + analogue filter! :twisted:
Sir Ruff
Band: Ruff in the jungle
Post by Sir Ruff » Sun Mar 11, 2007 6:47 pm
translucencecs wrote: I'm most interested in the Akai S612 for the combo of lofi sampling + analogue filter! :twisted:
bare in mind though that the "analogue filter" is basically just a tone knob... no rez, envelopes or anything. Anyone know what db/oct it is?
Do you even post on vse bro?
translucencecs
Yamaha SY-22
Roland MC-09
Roland M-VS1
Zoom ST-224
Dubreq Stylophone
Fostex MR8
Post by translucencecs » Sun Mar 11, 2007 6:52 pm
Yeah, I'm aware of that - I'm not specifically interested in a 303- or Moog-type affair - just something to mess with the sound a bit more!
