WIDE Open - Akai S612 - Opinions?
minime123
Post by minime123 » Mon Apr 16, 2007 9:54 pm
ok, good. :)
VINTAGE SYNTH DEALER
- https://tonetweakers.com
otto
Post by otto » Tue Apr 17, 2007 3:37 am
I'm considering picking up an AX-60 for around $225, he will throw in the s612 for $300 total. Is it really worth it?
Can the DIN jack on the synth be replaced by a 1/4 so I could process anything through its filter/effects?
hello darkness, my old friend
minime123
Post by minime123 » Tue Apr 17, 2007 4:39 am
personally, i feel thats a good deal. im not sure about modifying the din jack, youd need to ask a tech about that 1.
piRoN
Gear: A fair bit.
Post by piRoN » Wed Apr 18, 2007 10:38 am
You could convert the DIN jack into 6 x 1/4" jacks, I've seen it done on an X7000, but you'd probably be better served to make a breakout box/cable for it so that you don't mess with an original bit of kit. The pinout is easily enough found.
hinotori
Gear: /A1200/CVI/SIXTRAK/
SYSTEM100&100M/CS30/SK1/NORDG2/
Post by hinotori » Wed Apr 18, 2007 2:20 pm
im lucky enough to have an ax60 . could somone send me the pin info for wiring up a din to 1/4 inch cable to use the ax60 with external audio inputs . ? ?
also, i keep reading that the s1000 and s950 /s900 have this port for connecting to the ax60 . but on all auctions i look at i cant seem to see the plug/port on the back of these sampler models . . do they need on optional expansion card or am i being ignorant here . . could comeone help/correct/guide me here . . id love to get this great synth (ax60) running with an external sampler or audio in .
PM me to avoid hijacking this good thread . . thanks
Post by madtheory » Wed Apr 18, 2007 3:36 pm
hinotori wrote:im lucky enough to have an ax60 . could somone send me the pin info for wiring up a din to 1/4 inch cable to use the ax60 with external audio inputs . ? ?
It should be easy to figure out. There are 6 audio channels, and 12 pins (I think). So that's 6 positive lines and 6 negative lines= 12.
I don't know where you can get a 12 pin DIN cable. The AKG C12VR mic uses a 12 pin DIN cable, maybe AKG coud sell you one for you to change one end to 6 jacks.
Or contact Akai for a copy of the service manual, and based on that, build a break out box with 6 jack sockets to substitute for the DIN socket.
piRoN
Gear: A fair bit.
Post by piRoN » Thu Apr 19, 2007 1:49 am
It's actually 13 pins, the pinout can be found in the X7000 or S700 manual. There are 6 'hot' pins and one ground pin, the rest are disconnected.
otto
Post by otto » Thu Apr 19, 2007 5:00 pm
I might attempt a breakout box or at least a single 1/4 and let you all know how it goes. I don't really think I would normally need to run multiple lines in but I suppose it could be fun to route something in, out, and back in again.
How much architecture does it go through, the filter and the chorus?
Sir Ruff
Band: Ruff in the jungle
Post by Sir Ruff » Thu Apr 19, 2007 5:08 pm
otto wrote:I'm considering picking up an AX-60 for around $225, he will throw in the s612 for $300 total. Is it really worth it?
as a total price for the combo, $300 seems pretty good, but I would offer him $275-the 612 really is not worth more than $50...
Do you even post on vse bro?
fdneighbors
Post by fdneighbors » Thu Apr 19, 2007 9:46 pm
I have this setup and bought a roland guitar synth cable that works just fine.
Also, my busted s900 has the jack on it also.(FYI)
This combo is completely amazing, youll love it. I stack samples of my Bass clarinet and run it thru and its very trippy!
Post by madtheory » Fri Apr 20, 2007 10:32 am
Sorry piRoN, I somehow missed your post.
druucifer
Post by druucifer » Mon Nov 19, 2007 11:04 pm
i was wondering if anybody knew how to convert a regular 16 bit wav sample to the s612 format.
i have a program that will let me transfer smp files to an s612. but the only programs i've found that can convert a wav to an smp will only let me output a 16 bit smp file. when i try to load these onto the sampler, it comes out distorted beyond all recognition. i assume that the files are some sort of 12 bit .smp format. any help would be greatly appreciated...
