akai s-5000 or e-mu esi-4000?
- novielo
- Gear: in order of appearence:
sh2000 s612 nord modular mpc1000 kp3 ms-something cp-251 gameboy s6000 and other crappy stuff - Band: one-man band
- Location: by the river, st-jerome, quebec, canada, north america
hi everyone, i need your help i'm looking for a sampler and i would like your feedback on these models.
wich should i buy? i don't realy mind the difference speeking of ram between both. i'm more concern about the ease of use and sound they provide, looking on the fidelity (reproduction) of sound.
thanks alot for you help
forget the esi, and try to get an eos series like an e4,e6400, e5000....perferably an ultra, altho alot of ppl(myself included)prefer the sound of the classics...but the ultras do have a more mature os and expanded features....more lfo shapes and beat munging being the 2 biggest expanded features...the esi's are really cut down compared to the eos series...especially if u are planning on using it as your main studio sampler.
the akai's are nice, but i think the emu eos series really is the best 16bit samplers out there...im really surprised they arent mentioned on the vse itself, only here in the forums by users....the modulation matrix on them is super powerful....more like a modular synth then a sampler really....not to mention the filters on the eos destroy everything else out there.
the only downside to the eos compared to the akai's...no usb....scsi can be a nightmare if u have never dealt w/ it before.
- tallowwaters
- Gear: LC-MS/MS
- novielo
thank you, so i just look and when i found a good opportunity i'll just go for it. since i never had samplers i'll just get use to the one i got.
then wich one should be the cheapest? both without the expension bord. i think it would be the esi series? i haven't come across eos series as talked earlier, so i can't compare with this option.
my budget is 300$ shipped and ready to run, including hard drive or the scsi compact flash thing. i would keep the hdd only if it comes with it.
maybe this will give any other idea.
- hageir
- Expert Member
- Gear: http://www.geirhelgi.com/
https://soundcloud.com/geir-helgi - Band: Geir Helgi
IMO, if it's your first sampler, the s5000/6000 and those E-MU's would be bit of a overkill, right?
I'd suggest something more limited and "easier"
- novielo
hageir, uumm. well i'm not sure that i would buy one in the mind that i would have to buy another one when i get use to that one... i rarely think that things are overkill, in fact, i like to know that it will take a while before i get to know everything about a device.
i deffinatly need to store on a pc what i've done. i would overpass that criteria only if the unit is ultrasimple, like a s-612 (but they are kinda rare to find). but that would be as a second device.
but i'm all ears, what would you suggest, more limited and easier? the boss dr-202... hahahaha
- hageir
- Expert Member
trust me, I've had my share of overkill in samplers
I had the Roland S-750 with a monitor+mouse..
that thing was frightening!
I'm dying for a s1000 now..
After all this time of GAS-ing and going through a ton of gear, I've come to the conclusion that the simpler things are indeed "better".. IMO
I'm also dying for an SH-101
Since you are open for alternatives, I would have to recommend the Yamaha A4000. It is a killer sampler.
However; in what way are you planning to use it? Just for triggering samples, or for sound design? If it's just a playback device you want, then usb is a huuuuuge plus. If so, then go for the Akai and never look back
- hageir
- Expert Member
I read that the ESI series has some impossible to decrypt file standard.. (or maybe it was the A series, nah it was the ESI)novielo wrote:the akai seem a good choice, partly because of the wav format as native.
how about the esi-4000? is there a way to convert wav to it's format? i'll probably use the cf card adapter with it, if i get my hands on one.
so transfer back+forth is nearly impossible or something?
not at all, you can transfer back and forth to esi/eos with soundforge, recycle, zero-x beat creator, chicken systems translator, and a few other programs w/ no problems, as long as you have scsi connectivity...other wise, u can still transfer back and forth if u have chicken systems translator, and to a limited degree with cd-xtract....also any eos series w/ os4 or higher can natively read/write to fat formatted disc's(hard and floppy)...and also import/export to wav.hageir wrote:I read that the ESI series has some impossible to decrypt file standard.. (or maybe it was the A series, nah it was the ESI)novielo wrote:the akai seem a good choice, partly because of the wav format as native.
- novielo
when you say with scsi connectivity... can i use a scsi to usb cable?? because i'm using a laptop for recordingnick_emulated wrote:not at all, you can transfer back and forth to esi/eos with soundforge, recycle, zero-x beat creator, chicken systems translator, and a few other programs w/ no problems, as long as you have scsi connectivity...other wise, u can still transfer back and forth if u have chicken systems translator, and to a limited degree with cd-xtract....also any eos series w/ os4 or higher can natively read/write to fat formatted disc's(hard and floppy)...and also import/export to wav.hageir wrote:I read that the ESI series has some impossible to decrypt file standard.. (or maybe it was the A series, nah it was the ESI)novielo wrote:the akai seem a good choice, partly because of the wav format as native.
