Emu Emulator II, Drives, Floppies & S. Designer + Demos
stalla
Gear: CS80, CP70, Eminent U310 and more...
Re: Emu Emulator II Drives, Floppies & Sound Designer.
Post by stalla » Mon Mar 16, 2009 2:01 pm
Rob answered me. I'm waiting for the cable & cd now. I have an 4Go scsi from the 20th century... I keep you informed as soon as it's all set !
JMP wrote: No prob, good luck getting it all up and working. Which external SCSI HD have you acquired? Would fancy picking up a compatible one myself. Rob at Emulator Archive gets the cables made to order, mine took about four weeks or so.
EDIT : I got the cable and bought a SE/30 vintage mac !
In a synthetic mood
JMP
Re: Emu Emulator II, Drives, Floppies & S. Designer + Demos
Post by JMP » Wed Jul 08, 2009 9:36 pm
Bumping my old thread to share a second demo of Emu Emulator II library sounds:
Userfriend
Post by Userfriend » Wed Jul 08, 2009 10:08 pm
Great JMP..again!! :)
Band: Minim
Post by madtheory » Fri Jul 10, 2009 12:43 pm
Very nice JMP! What's the name of the pad sound in the first section? Is it factory or one of the other libraries?
JMP
Post by JMP » Fri Jul 10, 2009 7:59 pm
Cheers !The first sounds (keyboard split of two) is within the Burmer library, I forget the name but will check. The bass part is allocated to the bottom two octaves, the pad to the remainder.
Band: Minim
Post by madtheory » Fri Jul 10, 2009 8:12 pm
I'll trawl through my Burmer. I'd appreciate if you'd check tho, I didn't convert all of them :)
JMP
Post by JMP » Fri Jul 10, 2009 8:32 pm
Just checked, it's Ethereal Synth, Preset 01.
Band: Minim
Post by madtheory » Fri Jul 10, 2009 10:46 pm
Great thanks. I hope I can find it...
JMP
Post by JMP » Fri Jul 10, 2009 10:56 pm
I'm not sure if all their names actually match the original library names... I've noticed others with the same name and some are just numbers... :?
Good luck finding it, give me a shout if struggling. I still owe you one. :wink:
Band: Minim
Post by madtheory » Wed Mar 03, 2010 4:42 pm
FYI EMXP can now convert SD for EII image files into Soundfonts with all the mapping and looping intact, and it does a reasonably good stab at porting the modulation, amp and filter settings too. Fantastic!!
And I discovered today that Richard Burmer died in 2006. Very sad. His EMu factory sounds and his own Burmer library discs still stand up today, excellent, classic sound design.
JMP
Post by JMP » Sat Mar 13, 2010 9:17 pm
madtheory wrote:And I discovered today that Richard Burmer died in 2006. Very sad. His EMu factory sounds and his own Burmer library discs still stand up today, excellent, classic sound design.
I agree !
A couple of new EII track demo's here for those interested in the machine...... :)
http://www.vintagesynth.com/forum/viewt ... =8&t=55037
MIDI_Thru_Kid
Real name: Alex
Gear: KORG Radias
Roland JX-3P
Roland TR-505
Roland TR-626
Yamaha RX5
Yamaha TX7
hobnox.com
Drum Samples (All of them)
Yamaha Trombone
Band: MIDI Thru
Post by MIDI_Thru_Kid » Sun Mar 14, 2010 4:17 am
AWESOME SOUNDS! WOW!!
-Alex
"What I've noticed about this hobby/career is... You Just Can't Stop."
