Casio FZ1
wjmwpg
Real name: James
Gear: LoveRock, T40, MG500, JX10 4.0, D-50, Juno 60, VZ10M, CZ1, HT6000, K3m, SX240, Lambda, DSS1, Yamaha SY2, DX11, SQ80, MultiTrak, SammichSID
Band: Gospel Choirs
Re: Casio FZ1
Post by wjmwpg » Thu Jul 31, 2014 7:57 pm
I think I have this mostly figured out, but there's one part I still have trouble with:
Step 1: load a Casio sample set 3.5" floppy disk into the FZ's internal RAM.
Step 2: export that disk's contents as a .fzf file from the FZ's RAM to computer via MIDI cable?
Step 3: On computer convert the .fzf file to a .hde file using the HxC software
Step 4: Load the .hde file(s) from computer onto SD card
Step 5: Put this SD card into HxC floppy emulator (installed in FZ's drive bay in place of original FZ floppy drive) and load those .hde "disks" for use in FZ RAM.
Now here's the part I can't wrap my head around:
Let's say I get my hands on some "new" FZ sample sets on 3.5" diskettes, now that I've removed the original floppy drive from my FZ, how do I get the files from these new diskettes onto the computer in either .fzf or .hde format? Because surely not every single FZ sample set diskette in existence has already been converted to .fzf and shared somewhere online for easy download . . .
Cheers (like to think I'm thinking things through, or at least trying),
James
ahaigh01
Real name: Alan
Gear: Juno60, JX8P, Emulator II, FZ-1 FZ-20m, TX81Z, 01W, K2000, SY77, RX11, DR110, R8M, D4, MIDIBASS, Akai CD3000, CZ1000, Atari MegaST2, Mac Classic, PC
Band: The Advance
Re: Casio FZ1
Post by ahaigh01 » Mon Aug 04, 2014 4:44 pm
Hi James,
Well I haven't yet purchased the HxC yet but I plan on still doing it. Did just buy a collection of FZ floppies off ebay, but they haven't arrived yet.. Your steps 1-5 look correct. But yes, once you have removed the actual floppy drive you face a dilemma. My solution will be based on the fact that I have 2 FZ units and one will retain a floppy drive for loading real floppy disks. Then with the FZ to FZ cable I built I can transfer the banks to the FZ with the HxC installed and save to a virtual floppy. It should be possible to get the data from an FZ disk on a PC that has a floppy drive using Omniflop and then the HxC software. I don't have any first hand experience with this however....
wjmwpg
Real name: James
Band: Gospel Choirs
Re: Casio FZ1
Post by wjmwpg » Mon Aug 04, 2014 8:57 pm
Thanks for the reply. Posted the same question on another forum and got quite a detailed reply from Jeff at HxC. He outlined 4 or 5 options that would enable me to continue to read and dump FZ diskettes after the HxC emulator install. The last option was a great surprise - Jeff said I could send diskettes to him at HxC and he'd transfer them to .fzf / .hde for me! How's that for customer service?!?
Robber1956
Real name: Hobb
Gear: Yamaha DX100,FB-01,TX81z,TX802,TX7, YS100
Casio FZ1,FZ10m,MG500
Roland MT32,D110
Fender Strat, Ampeg VT40
Atari MegaSTE, MegaST4, STe,STfm, MiST
Re: Casio FZ1
Post by Robber1956 » Mon Aug 25, 2014 4:51 pm
Hello,
edited update
i have a problem which I really need to solve.
When connecting the FZ1 to the FZ10 with the FZ to FZ port cable (see previous posting) there is an audible noise of approximately actually +/- 196 hertz (key G3, I said 50Hz before :oops: ) coming from all outputs of both samplers. It's there all the time and is really disturbing. Disconnect the cables and it is gone.
I tried everything like resoldering, earthing and unearthing the power plugs, put them in the same and in different power outlets, different mixer. Kept them away from other power- and datacables, swapped the cable etc. The noise coming from the FZ1 is more distinct than from the FZ10. Even if I shut the FZ10 down it is still coming from the FZ1. The other way around there is less noise.
When transferring data through the port cabkle that becomes audible as well. I guess we all heard that sound before in other audio equipment like synthesizers and digital mixers.
Data transfer itself is no problem and goes smoothly. No corrupted data or time outs.
Did anybody who is using a simalar set up face the same problem?
Is there a solution? Will putting resistors between the pins and wires help? Or is the wiring described by Jeff McClintock in the pdf.file correct?
http://www.warningwillrobinson.com.au/I ... mation.pdf
The main problem of course is that if I want to use the FZ10 and the FZ1 together I want to be able to load the FZ10 through the floppy emulator of the FZ1 using the port cable and not use the floppy drive in the FZ10 or, least of all use mididump.
I will make another cable now because I didn't try a proper shielded cable, just an old 25 wired printercable (need only 16 according to the wiring scheme), but I'm very pessimistic about the result. Worst case scenario is that there is a error in design of CASIO's FZ1 port. That leaves me just using the cable occasionally for data transfer from the FZ10's floppy drive to the FZ1 floppy emulator's SD card and afterwards disconnect the cable. :( Not really an option.
Robber1956
Real name: Hobb
Roland MT32,D110
Re: Casio FZ1
Post by Robber1956 » Thu Mar 12, 2015 5:35 am
Robber1956 wrote:Hello, I have a problem which I really need to solve.
It seems that it's solved now. A resistor (don't know yet which one) or preferably a switch will do the trick.
http://torlus.com/floppy/forum/viewtopi ... 8&start=60
Robber1956
Real name: Hobb
Roland MT32,D110
Re: Casio FZ1
Post by Robber1956 » Sat Jun 06, 2015 12:53 am
Hello again,
(some cut and paste from the HxC forum: http://torlus.com/floppy/forum/viewtopi ... 030#p11030 )
Replaced the backlight panel for the FZ10m yesterday. The old one was real dim already and getting dimmer in time, barely visible in the dark and also caused problems. After a couple of hours in use port cable transmission failed and no sound was coming out anymore.
First I thought it was due to lifting ground. See postings about this subject on the HxC site "Miscellaneous Keyboards/Samplers".
Port transmission faillure happened before, but next day everything worked again as usual. This should have rung a bell.
When there was no sound anymore I knew it had to be the backlight panel so a week ago I ordered two panels from Backlight4you,
http://www.backlight4you.com/index.php/ ... ments.html
A soft-yellow which is now inside (but rather than yellow shows a bright, green glow} and a blue-green as a spare.
How to do this. Well, just get the front panel of the FZ10 of and disconnect and remove the print with the display panel on it. Leave the panel attached to the print! Desolder the LE-panel connecters from the print. The LE-panel might be glued to the print which makes it almost impossible to pull the panel out underneath the display. With a spareblade from a utility knife, because it's thin enough to get it under the EL-panel, you can carefully cut the EL-panel free.
Slide the fresh EL-panel in and solder the connectors to the print.
ahaigh01
Real name: Alan
Band: The Advance
Re: Casio FZ1
Post by ahaigh01 » Thu Jun 11, 2015 3:33 pm
Thanks for posting this. I've been seriously considering replacing the backlights in my FZ-20 and FZ-1, so this will be useful info.
gmeredith
Band: Warning Will Robinson
Re: Casio FZ1
Post by gmeredith » Fri Jun 12, 2015 12:53 am
The FZ-1 is easy, and is completely different to the racks. You just open the bonnet, undo a few screws and it's out, with a lead and a block connector attached to it. The racks are soldered in. I have a VZ10m with a dud backlight, it should be identical to the FZ10m - thanks for the instructions! I was thinking I had to pull the display off the pcb. That's great news.
ahaigh01
Real name: Alan
Band: The Advance
Re: Casio FZ1
Post by ahaigh01 » Sun Jun 14, 2015 1:41 am
Here are some cool Casio things I found on Ebay and scanned. The Casio Professional Music Products Catalog - FZ-10M Brouchure - VZ-10M Insert - 1988.pdf
http://www.mediafire.com/view/jjdp8miv8 ... -_1988.pdf
ahaigh01
Real name: Alan
Band: The Advance
Re: Casio FZ1
Post by ahaigh01 » Fri Jun 26, 2015 2:41 pm
Robber1956 wrote:
ahaigh01 wrote: the keys are just a bit sticky because the foam rubber strip that the keys rest on is starting to go bad. I would like to replace that.
I had the same problem for years. So last year or so I decided to do something about it. I went to a litttle shop downtown where they sell ship equipment and found a self adhesive cell.rubber strip 10mm (0.4 inch) wide and 3 mm (0.1 inch) thick for 50ct a meter (about 3 feet, enough to cover the whole length of the keyboard). Fitted just right. You can find this everywhere on the internet. Just cut away the old rubber strip with a utility knife and remove the remains with some sticker remover and put the fresh one in. The keyboard now plays as smooth as if it was brand new and is really quiet, no rattling noise anymore and no sticky keys.
Robber
I did this repair to my FZ-1 last night. The process is fairly involved. You must remove the entire keyboard and remove every key. There is a self adhesive clear plastic strip that locks the ends of each key into its slot - this must be peeled off to release the keys. I threw it away when done because the keys are in no danger of coming loose when put back in. The spring holds the key in place and you would have to press extremely hard at the back of the key to get it to release from its slot without the strip in place.
Then I removed the old foam rubber strip. This part was hard because it had to be scraped away bit by bit with a knife. It took over an hour. The new strip I ordered was 10mm by 3mm, but this proved to be too wide because it overlapped some screws, so it had to be trimmed to about 6mm. Then just reassemble everything.
The keyboard feels great now! :D
Robber1956
Real name: Hobb
Roland MT32,D110
Re: Casio FZ1
Post by Robber1956 » Mon Jun 29, 2015 10:43 am
Just the rubber strip. After 25 years it was beyond recognition. one sticky, almost liquid mess. Didn't know with what to replace it. That was the hardest part. Once I found a suitable replacement it was easy. Especially using the sticker remover to get rid of the remains. First I thought to use the strip over the whole length but where the screws are in the way there is no contact with the keys so I cut it up rubber strip to fit the pieces between the screws. Really, if I play the keyboard all keys play so smooth and quiet now. Never had a better keyboard before. Only a pity that the max number of notes out you can play at the same time is 8.
Just another thing with the (mine?) FZ about both (DCA & DCF) envelopes. This has bothered me from day one. Setting the keyboard rate scaling/key follow and velocity sensetivity lower than the max. creating slower attack is really infuencing the parameters in an almost uncontrollable way. In fact it's all or nothing. Especially the decay rate. It "eats" up almost the complete first part of a sample.
A very complicated and thus unwanted way to get around this is to insert 'silence' in front of the sample. Perhaps it's possible to adjust the attack curve for the envelope somehow.
I tried to do it by making use of al the 8 steps of the envelopes using all possible decay and level settings, but it's still all or nothing. Very poor performance, in fact quite useless.
303ish
Re: Casio FZ1
Post by 303ish » Fri Jul 10, 2015 12:29 am
Can I use a FZ-10M to filter external audio without sampling it, in real time?
gmeredith
Re: Casio FZ1
Post by gmeredith » Fri Jul 10, 2015 2:17 am
No, the audio path isn't direct - you can't monitor the input via the outputs
Robber1956
Real name: Hobb
Roland MT32,D110
Re: Casio FZ1
Post by Robber1956 » Wed Jul 29, 2015 10:35 am
Ebay:
http://www.ebay.nl/itm/291518853199?_tr ... EBIDX%3AIT
310,00 GBP
Zjeezzzz :o it's becoming a very populair Sampler.
Got mine for 100 GBP/150,- euro
Robber1956
Real name: Hobb
Roland MT32,D110
Re: Casio FZ1
Post by Robber1956 » Wed Jul 29, 2015 12:26 pm
It went completely wrong.
Changed the EL of the FZ1, had to do it because data transfer through port cable was getting worse and I use it for loading the FZ10m (it also is a sign of things to come :( ).
After I changed the EL that problem was solved, but not for long with only 3000 hours to go. The EL that came out was from Backlight4you. Exactly the same as the new EL.
Perhaps I should switch off the EL panel during normal use and when editing and transfering switch it on, modding an external switch somewhere to save lifetime. Don't like it though.
Before all pixels where allright, now I lost partially top (which says 'main menu') and middle row (effect/midi).
Not a real disaster but still.
I know what I did wrong. I should not have touched the display itself at all (but I saw them doing it on all these sites concerning the replacement of the EL panel :? ).
Just DO NOT TOUCH the display. Don't unscrew the frame which holds the display. The slightest movement will break the very fragile connections between the ribbon cables and the display.
Just remove everything around it (midi panel, audio patch panel etc). and then pull the old EL out, which in this case was quite easy to do and shove the new one in. Still I can't guarantee that this will leave the connections unharmed. It simply reduces the chance that this will happen.
So within a year or two I wll need to change the backlicht in the FZ1 again. No EL panel anymore but leds or actually a single led.
Just like the one I put into my Yamaha TX7. That was really easy and cheap (Saymlove Ebay, 16 characters one line "1601" US $ 3,59). The DX100 will be next but is not so easy unless I can lay my hand on a similar LCD like the one in the TX7 but with the led on the left instead of the right side of the display so I don't have to cut away anything inside the DX100 and remove the only lovely red led this synth has on the right side of the display.
This type of LCD has just one led (5 v) and a piece of plastic that disperses the llight which gives a very even glow all over the surface.
So just a led (perhaps RGB with remote control to get any colour) and a piece of plastic diffuser cut into the right size and flat enough to fit underneath the display just like the EL (there is approximately room for 2 millimeters/0.1 inch) is all I need.
The solution to get the lost pixels back is perhaps to put some extra pressure on the LCD frame but it can also ruin the whole thing all together.
